Question about Sony Playstation 3 (PS3) Console
Done hard reset on ps3 slimline but still having no picture through av or hdmi just black screen and no sound. all cables are working due to testing on another machine.
    Novelist:
    Sniper:
  • 90 Answers
Hi stanthema953,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your graphics has overheated. You just need to stop the heat build up in order to make it work again.
Solution:
The first way you can fix the No Display Error is by sending it in but bear in mind for this problem there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
You can find them all here:
Click Here For A Closer Look At All The PS3 Repair Guides On Offer And How They Work
Posted on Apr 09, 2011
Ressetig the ps3 on a new tv
Sounds like the Tv your using is faulty. Its could have hardware failure. You did say it PS3 was working on hdmi on a plasma. If your using the default hdmi cable that came with ps3 that also can be faulty. I have always had problems with the default hdmi so i bought a new one that was not SONY and it works beautifully. Another thing the black screen with green is a video cable or graphics issue.
Does this tv work if there is no ps3 connected? if so i recommend using the standard PS3 Component AV Cable. see if that will let you reset your ps3.
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
Ps3 shows no picture on hdmi cable, and only beeps 1 time
Remove your av cables on the back of your flat screen,I have a Wii and it is doing the same if there are av cables plugged in the back of my screen it just will not work,this is due to certain products that have software floors or bugs that they only work with one cable so its HDMI or AV your choice
Dec 25, 2013 | Video Game Consoles & Games
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
3. Listen for one long beep, followed to two shorter beeps.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
I have a new ps3 slimline,cant get a connection t my samsung HDTV
What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
What to do with my Ps3??
Your PS3 auto-adjusted to the HDMI Input cable, so you will need to find somewhere that you can either get an HDMI cable or a HDMI TV, so you can view the screen. Then you can hook up the A/V jacks and go to your Videa and Audio Output Settings and choose them, disabling the HDMI hookup selected. Then you'll be back in business!
Sep 29, 2009 | Video Game Consoles & Games
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
My PS3 console doesn't display picture.
when the ps3 is on standby (red light) , keep the [ower button pressed at the front until between 5-10 seconds, until it beeps the it should work
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
