Question about Samsung SyncMaster 940MW 19" LCD Monitor
My samsung lcd tv screen is going blank or black out but audio is present, same prob when with cable or dvd device sources. thanks
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 10, 2011
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Hi! I was watching my TV - Samsung LN-S4092D - and the picture went to black with a few very light horizontal lines for about 30secs. After that it went to complete black. I thought it might just be that...
Hi Bob. The first Board to cause this problen is the Main bd. The next bd to cause this is the T-Con bd which is mounted on the Panel. Since you saw horizontal lines and that you have text on the screen and are missing audio from the tv means that the Main bd has gone bad. Have a trained Samsung tech service your tv. Call 1-8020-Samsung as they can direct you to a Qualified tech in your area.
Jul 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung tv prob
My daughter's LCD which is barely used started showing horizontal coloured lines.I read that the LCD's are vunerable to static/charge build up and also power surges.
I unplugged my daughter's TV and it is now working properly however we now unplug the TV when it's not in use.
I was considering purchasing a larger model for the faily room but Not going to waste my money until they improve this rechnology.
Good luck to all.
Cheers!
Mar 22, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung SyncMaster 940MW 19" LCD Monitor Logo
192 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
