Question about Kitchen Ranges
Maytag Neptun Dryer won't come on. I move to a house where the wall outlet for the dryer is for a 3-prong power cord. My Neptune, which is at least 10 yrs old, had a pwer cord with 4-prongs. I wnet out and purchased a pwer cord with 3 prongs and replaced the cord on the dryer. However, when I plug it into the wall outlet the dryer still does not come on. Whats wrong? The Model # is MDE3000AYW. Thanks
  • 4,323 Answers
Hi
If this is how you have inserted all the wires
then please check/test the thermostat/thermal fuse for continuity which is located inside the back panel towards the duct. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 09, 2011
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
Changing 3 prong to 4 prong outlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My power cord does not fit the electrical outlet in my new apartment _ maytag Neptune electric dryer. Is there an adapter to change the cord from 3 prong to 4 prong
You need to go to a local hardware store and buy a new cord. There is an adapter but it is more exspensive than the cord and I have seen problems with them overheating because of the fine dust getting in them. Your cord is easy to replace there is a access panel that is held on by a screw where the cord goes into the machine. You will need to remove the screws holding the electric wires there will be 3 on your dryer. The 4 wire cord has an extra ground. You can put this under the screw that holds the access panel on. The two outside wire connectors on your dryer are the hot wires each carries 110v the center wire is the neutral wire and also acts as a ground on a 3 wire dryer. The 4th wire is an ground for house trailers and some areas require them as a seperate ground from the neutral. I hope this helps
Aug 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer loses power
YOU NEED TO HAVE AN ELECTRICIAN,OR SOME ONE WITH KNOWLEDGE AND A METER TO CHECK YOUR VOLTAGE..PLEASE DO NOTING ELSE! YOUR ASKING FOR A FIRE..I KNOW THIS ISN''T THE ANSWER YOUR LOOKING FOR BUT IT MAY SAVE YOUR LIFE...RDS
Apr 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
