Question about Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower
The belt came off of my Lawn-Boy self propelled 10642. How do you get it back on?
SOURCE: no spark
After seeing what you and other ASK type web sites charged to answer my question, i called the dealer he answered the question for me. i ordered the part online and repaired it myself.
My advise before you pay anyone to answer your question try calling a local repair center, i found they were willing to answer my questions without a CHARGE
Posted on May 19, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
  • 202 Answers
SOURCE: rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Posted on Jan 26, 2010
How do you tighten or loosen a belt on lawn boy self propel mower? Where is the tension pulley bolt located to tighten?
most self propelled mowers engage an arm to put the gearbox into drive so it may not be a case of loosening the drive belt
May 06, 2015 | Garden
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
I need an engine diagram to help me put my lawnboy 10642 briggs and stratton eng ine back together
Go to partstree.com and search your model number and you will see an exploded view. Thank you for using fixya.
Aug 22, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
I have a Lawn boy 10696 mower that seems to need a new self propel belt. Is this something i should bring in for repair or something the average homeowner can replace?
This machine is kinda tricky. Took me a bit to figure it out, so you may want to take it to the shop where they can do it in a jiffy. If you take that back top cover off, you can get at the belt from there. I can't remember, but I think then you have to go underneath AFTER REMOVING THE SPARK PLUG WIRE!!! and remove the blade to get the other end off. The proper replacement of the belt should be outlined in detail in your owner's manual. I work on so many different machines that I cannot remember the exact way that I did it the last time, but I know it was a pain in the A$$. Hope this helps.
James
Oct 21, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Rerunning the belt on an o6 self-propelled Lawnboy
Apr 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Briggs & Stratton LawnBoy 20Inch 65 HP Gas Powered Variable Speed Rear Wheel Drive Self Propelled Lawn Mower Logo
829 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
