Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Can you remove the filter that sits on top of the motor
    Scholar:
  • 143 Answers
Yes but it is supposed to be a liftime filter
Posted on Apr 14, 2011
Will run for a few minutes, then red light comes on canister an unit shuts off.
That's the thermal cut off circuit. If the motor gets to hot it trips and shuts it off. When it cools down it will turn on again but it is generally an indicator of one of the following; the cone filter needs changed or the inner filter ring that sits above the motor inside the unit is shot. One is an easy change the other requires dis-assembly, better carried out by a vac tech if you aren't comfortable taking it apart. In the meantime remove the cap out of the top of the vacuum, that will let it exhaust heat better but I strongly recommend getting that filter ring changed.
Nov 27, 2015 | Filter Queen Majestic Canister Vacuum
My canister motor shuts off after a few minutes and a red light comes on
My filterqueen majestic is 10yrs old and just started to spark and smell of burning ive took it apart
If you have a burning smell from the motor, your motor is shot. You should be able to buy anew AMTEK Lamb motor for about $85-110 US. Request a double ball bearing motor as it will have a longer life span.
Also buy a fresh internal filter kit. There will be a small 5 .5 inch filter disc inside the cone protecting the motor in the event that the cone tears. Replace it .Also save and reinstall the small insulating disc that sits between the top of your motor and the screen at the top of the vac. This is to prevent electric shock. This disc is the size of a coin.
Post back if you need more help. Wiring is very easy. Do NOT twist your wires before installing into the connectors, twist the connectors, then tape to be certain they are on tight.
Nov 04, 2009 | Filter Queen Majestic Canister Vacuum
I want to know easy way to change my filter
There are only two. One on top and the paper cone filter that covers the entire base of the top. There are three paper tabs on the large paper cone filter. You can either put the filter directly on the bucket and then bend the tabs over the outer edges of the bucket to hold it in place and then sit the top down ( that's how I do it). Or you can put the filter on the plastic cone shaped frame on the bottom side of the top of the machine. It's actually easier if you flip it upside down and then flip the bucket base over onto it.
The only other filter is on the very top of the machine. Unscrew the top lid which is actually the cover for your exhaust hose inlet. This filter is indexed with a couple of screws that don't have to be removed. Spin the metal cover and remove filter. There is actually a large round filter ( hoop shaped on the top of the machine...I can't remember how I remove it, but truthfully it has little air restraining capacity so unless you have an odor issue with your Majestic what you can do is blow it out using the hose connected to the top of the machines exhaust blower outlet. Don't ever remove that filter, just literally leave it where it's at and put on your crevice tool and aim it through the slots around the top of of the machine.
Oct 01, 2009 | Filter Queen Majestic Canister Vacuum
Where does the hepa filter go
Look for a removeable grille at the top or back of the vac shaped similar to the filtter. The filter is an after filter so it sits beyond the bag
Sep 10, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Motor Filter Has Been Sucked In - Eureka 4467AV Upright Vacuum
you will have to remove the cover over the motor so you can get to it and the fan. When you get the filter out, drill holes first, then drive a couple of nails down thru where the filter sits so it can't get sucked into the fan again.
Jun 02, 2008 | Eureka 4467AV Upright Vacuum
Why does my dyson dc04 work for about 5 mins then cut out
I spent 4 years working on Dyson v/ceaners in the Uk
So, heres what to;
Check your filters - and for blokages in the hose and brush comparments,you have one in at top of the bucket called pre motor filter and one on top of the motor where the bucket sits called post motor filter. If these are worn and mucky wash them or replace.
Switch on your Dyson with no filters in and leave running to see if it cuts out. (in side on the motor their a liitle device called a TOC thermal over load cut out device. when the motor runs too warm - the TOC with cut power to the motor and will work again when cooled down.
Good luck.
Mar 18, 2008 | Vacuums
Filter Queen Assembly
On the rubber piece, there is a groove on the inside edge for the screen first, then the filter. Just have to work them into that slot. Then put over the bottom housing. The round paper filter is put on over the tank, then the top unit sits on that. These filters will keep dust out of the motor and head asm.
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
15 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
