Question about Epson DFX-9000 Matrix Printer
Dx7400 hi when i print a photo there are lines going across the photo about 1.5cm apart down an A4 paper can you help me i have just got this printer a month or so thanks EK
  • eleanor454 Aug 06, 2008
  • 101 Answers
Goto a microsft word and write:
THIS IS A TEST (large font), IN all the colours on the ribbon including black.
This will test the action of the pins striking each section of the printer ribbon, then at least you will know what you are dealing with
Posted on Aug 06, 2008
  • asjadm Aug 06, 2008
    if the test I decribed to you worked perfectly, then the faults lies elsewhere than the printer head.
    the lines across your photos indicates that a pin has not been firing during that line of print
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
When printing photos especially A4 size my printer leaves white dotted lines across the photo
This is caused by the paper feed wheels (small spiked metal wheels to draw the paper through the printer.) Unfortunately, there is no way I know of to fix this, but you could try using different types of photo paper.
Aug 15, 2010 | Epson Stylus Photo R300 InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Jan 05, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lines across the tail end of small photos
Your printer sounds as if it has a hatred for one type of paper size!!! Seriously, it could be a positional blockage, ie debris in a place that allows large paper no worries, but as soon as it repositions itself to do 4x6 it catches a block. open unit if you can and thoroughly check for debris, ie papeer bits. Hope this helps. Also give your printer some tlc, clean heads, both manually with solution and cotton buds, and run print tests, clear print jobs memory, and try unconnecting and reconnecting cables, and powere supply.
Aug 11, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Epson DFX-9000 Matrix Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
