Question about Maxtor DiamondMax 11 400GB 7200rpm 133MBps Ultra ATA/133 (ATA-7) Ultra ATA/133 (ATA-7) In... (6H400R0FT) Hard Drive
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my PC) and thank you MR.Khalife
  • 1,719 Answers
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Posted on Apr 09, 2011
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
I can't format my HP Compaq 6720s Notebook,win xp say can not hdd drive ,but i'll get new hdd
The reason XP cannot detect the hard drive is because thr hard drive in this model HP is a SATA hard drive and the Windows XP installation CD does not have the SATA controllers on this CD.
To install XP on a SATA hard drive, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 03, 2011 | HP Compaq 6720s Notebook
Dears, I cannot install Windows XP to my Aspire 5710Z, System cannot detect by HDD. In Bios is HDD visible, instaling Windows Vista by Acer CD Anytime upgrade works. Many years ago we was using...
Hi Tom!
You DO need the SATA drivers diskette! Download it from here.
The easiest way will be using a USB Diskette Drive... Follow the instruction in the included README file (section "5.3 Pre-Installation Using the F6 Method") to complete your Windows XP installation!
If you can't find any USB Diskette Drive - it's a little more complicated... Follow the instructions here!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck and best regards,
Pelu.
Jan 04, 2011 | Computers & Internet
Install internal hdd into external enclosure
yes you can... needs to be the right type i.e. SATA or EIDE that matches your enclosure and (USB) interface board...
Feb 25, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
System keeps freezing NO TASK MANGER OR POINTER OR KEYBOARD, also event viewer shows no sign
It could be that your Hard Drive is almost gone, or, that the system file is corrupt (but you would get a system error with this, pls advise if you do). In the case that your HDD is dying, I would recommend that you try and backup all your data asap to an external USB Hard Drive.
If you do happen to have another working computer around you can try this, but first you need the following:
1 external USB Hard Drive case that matches your PC Hard Drive fitting, ie. IDE or SATA.
2. A Windows XP cd with serial key.
If you do, then carefully disconnect all power to the problem PC, and carefully remove the Hard Drive.
Open your external USB drive case, and carefully remove the HDD, be careful not to drop any of the HDD - treat it with care.
Now insert the problem HDD into the fitting/connection that is either IDE or SATA, matching your case's fitting.
Close the case, dont have to insert the screws at this point, and hook it up to your spare working pc.
It should pick up on the screen as an external USB drive.
First, scan it for any viruses and clean it if any picks up.
Now locate all your data from Documents and Settings/Username/Desktop and My Documents and Favourites too.
Copy these files to your spare PC's Desktop with a New folder created and labeled.
After you transfered all your data, then disconnect from working PC, remove case of external usb drive, remove the HDD of the problem PC and insert it back into the PC body.
Insert the WinXP cd into the CD ROM drive and wait for it to boot from CD, then attempt a repair. Else, reinstall XP and follow the instructions on the screen - they're user friendly, and dont be scared:)
Jan 27, 2010 | Acer Aspire One PC Notebook
Problem installing xp
SATA hard drives have become more and more appreciated tending to substitute the IDE drives due to the increasing speed they offer. Motherboard manufacturers started to implement the new standard years ago, when the technology was young and expensive. Now, as the SATA HDD prices have lowered to a level where anybody can afford to choose a SATA enabled HDD instead of an IDE one, a great migration has been observed among the common computer users.
They choose to install Windows and applications on SATA drives because they provide more speed which determines the system to run smoother. Thus, for those owning older mainboards with SATA support an extra step is required while attempting to install Windows XP. Windows XP does not provide drivers for all the SATA controllers, therefore, during the installation procedure, the user must insert a floppy with the drivers that came in the package along with the motherboard.
Not a big deal, not much effort, but the funny thing is that a great number of people passed on their floppy drives. Under these circumstances, no floppy means the impossibility to install Windows XP on SATA (on some mainboards). The result? The installation guide simply won't detect the SATA HDD.
People that were happy they got rid of the old removable drive have now motives to worry. Some may reconsider buying new floppy drives for their computers. Even if I wrote in a precedent article about the utility of the floppy drive, I do not encourage spending your money buying back an obsolete piece of hardware. I will present you a method to avoid this inconvenient by doing a software trick.
Let's take it slow. Where is the problem? We have a driver problem strictly because the SATA driver we need does not come embedded in the Windows XP installation package. What if we add the driver by ourselves before installing Windows?
What ingredients are involved in this operation? The original Windows XP Installation CD, a freeware application named NLite and a blank CD. Moreover, we need the drivers for the SATA controller provided by the manufacturer. In case you did not find any floppy inside the motherboard package or you cannot locate them on the mainboard
installation CD, you can consult the manufacturer's website to download the latest versions. To do the trick I have been talking about, it is assumed that you already have a Windows installed on an IDE drive. In case you don't, pay a visit to a friend and ask him to let you use his computer. It won't take too much time, I guarantee.
So, download the drivers and unzip them (in case they come archived) in a desired location. Then download and install the Nlite application. When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
I tested a Windows XP Home Edition and it seems that it required about 566 MB. Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Insert and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
Review image Review image
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver.
May 09, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
Instation of Maxtor diamondmax 21, 160 GB which is connected to my pc running Xp Home. The Bios and xp home do not seem to recognize it. How can I get a installtion software. Please help.
dont think you need a driver unless you are installing it in a raid ...the purpose of sata was to elliminate hdd jumpers and configuration ... just go into the bios and make sure the sata channels are enabled
Mar 21, 2008 | Computers & Internet
Boot my cpu on sata hdd how i can do whit widows xp plz help me ..:-(
You will be able to get driver from the drives makers website.
Jan 05, 2008 | ASUS P5LD2 Motherboard
Computers & Internet Logo
217 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
