Question about Ford Car Audio & Video
Radio wont power up fuses ok, bought another radio , same thing, tried both radios in wife.s truck both work
  • Ford Master
  • 6,674 Answers
Radio system has usually at least 2 different power supplies, one for radio (when key on or in accessories position) and one for memory, which is a constant 12 volt source. Have you checked to make sure you have both of them? Make sure you have a good ground source as well. Here is a link to go to and look up your vehicle for stereo wiring. It will tell you what color wire in the harness does what, to make it easier to find problem . Scroll down page and click on your make, then model etc. then stereo wiring.
http://www.the12volt.com/
Posted on Apr 09, 2011
2009 suzuki swift radio and clock not working changed fuse but ok still not working
can only be 2 things
lost power to radio (bad fuse, or bad radio ground)
radio dead. (time to upgrade?)
if not a stock suzuki radio, it can also be the hacked wiring
bad from installing that aftermarket radio ,
Jan 14, 2017 | Suzuki Cars & Trucks
1998 Jeep Wrangler the radio went dead but cigarette lighter works and fuse is ok. The next day the check engine light came on. Any idea what is going on
radio dead, that means no sound or nosound nor dial data?
does the am/fm and cd all fail, using real CDDA disks(store bought)
? if the radio is totally 100% dead that is lost power to radio.
fuses or lost ground to the radio.
the check engine light means one thing,.
get the car scanned, 1996 to now, all cars USA.
you scan it, they scan it.
i take it car starts and drives perfectly?
head lights work> and all outer things?
Jul 04, 2016 | 1998 Jeep Wrangler
Dodge ram radio
There were three sound sytems offered in the 2003 model year. If 20A fuse 14 and 15A fuse 1 in the fuse block are OK, power should be getting to the radio and the separate power amplifier. The amplifier may be defective or the connection to the factory radio may be defective.
Feb 13, 2014 | Cars & Trucks
Chevrolet Venture Problems
What is the circuit in question powering? There is more than just a radio, there may be amps, antennas, clocks, and lights in the radio that is a separate circuit. Look close at the wiring diagram and make sure none of those things apply. For example, if the antenna gets power from the radio, but is fed from another fuse, there is the tie. Or speed sensing control, ties to the speed control and feeds through the radio. Things can get complicated. You may also have a shorted or miss wired device. If anyone has changed the wiring or components from factory, I would suspect that first.
Nov 16, 2013 | Cars & Trucks
I have a 2000 chevy venture minivan that wont start due to a short. it blows fuses only when i plug in the stero system. i bought another stereo thinking it was a bad radio but it does the same thing.
to isolate your problem: run a power source from auxiliary power from the fuse box to your radio, connect this to your radio where the fuse connector, this will not interrupt any other fuse which cause to blow due to over loading. Your radio should work w/out any interruption. good luck.
02Ford Taurus windows windshield wipers locks wont work
Sounds like the wire you used for power was oon the circut for all those other things, or if you pulled the fuse box down to hook radio up through the fuse box, you may have grounded out some wires, or knocked them loose. Use a test light or voltmeter and make sure you have power at the fuse box for wiper,dashlight, trunk release, door lock fuses.
Mar 09, 2013 | 2002 Ford Taurus
Radio stooped working. I bought a new one and it wont work either. I thought I checked to fuses. What fuse powers the radio?
Check all of your fuses. Today's radios require two power sources to work. One constant (to retain memory) and one switched.
Apr 11, 2011 | Car Audio & Video
99 voyager no crank, wipers, radio and power windows. bcm?
Check power distribution panel near battery for blown fuses.
Feb 08, 2009 | 1999 Plymouth Grand Voyager
Radio not working.
Check all your fuses. There is a fuse for radio ONLY. Find the radio fuse and check it.
Jul 18, 2008 | 2005 Nissan Altima
Car Audio & Video Logo
80 people viewed this question
Top Ford Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Ford Car Audio and Video Expert? Answer questions, earn points and help others
