HP Photosmart c5280 "error 074a4dd6"
Basti
  • 1447 Answers
SOURCE: how do I install an
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
Posted on May 15, 2008
ginko
  • 19396 Answers
SOURCE: HP photosmart C5280 Manual
Manual here: Manuals
Here is the support page with more documentation:
HP Photosmart C5280 All-in-One Printer
Posted on Jan 05, 2009
  • 3 Answers
SOURCE: My HP photosmart c5280 keeps
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
Posted on Jan 29, 2009
Wiired
  • 122 Answers
SOURCE: Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Posted on Jun 22, 2009
vegakitten20
  • 685 Answers
SOURCE: HP Photosmart C5280 All-in-One Repair manual
http://www.retrevo.com/support/HP-C5280-Multifunction-Printers-manual/id/3124dj192/t/2/?cmpid=Manuals_HP_Printer_Specific_Models_Broad&s_kwcid=HP%20c5280%20manual'6505891971&adsense=2257534859&gclid=CNDKyJeH76YCFUbf4AodEDBYEw try here and let me know how it works
Posted on Feb 04, 2011
I had unplugged my printer for the last week and when I plugged it back it it read error and the numbers 074a4dd6 showed briefly on the screen.It read to turn power off and on again.Tried that and to no...
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.
Oct 18, 2011 | HP Photosmart C5280 InkJet Printer
Red exclaimation mark on C5280
Try first unplugging power cable, and see if it clears the error
Jul 29, 2008 | HP Photosmart C5280 Printer
Hp c5280 says scanner error when i try to scan a page
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts. Sometimes loose contacts will be the cause for scanner error. This will solve the problem for sure.
Thank you!
Jun 05, 2010 | HP Photosmart C5280 Printer
HP problem
HP C5280 "Refer to printer documentation" error
Feb 22, 2010 | HP Photosmart C5280 Printer
Refer to printer documentation error message
I kept having the same problem as what was experienced by gobigforgod. What should I do ? Pls help.
Mar 26, 2009 | HP Photosmart C5280 Printer
204 people viewed this question
k24674
jasbo
jasbo
