Question about Acer Veriton 7600GT PC Desktop
My ACER Desktop supplied by our home office has first a problem that it constantly shuts down and starts up again after a while, the person I gave the computer for fixing had it reprogrammed with windows 7, after a while I could not print from any port, when I updated the version of windows it did not pass the windows security check, I now would like to go back to the original version of windows supplied with the computer, the computer came with a formatting disk and 2 windows vista disk, how could I roll back to its original format?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 37 Answers
Use the disc you say you have and reload the software. You will loose any and all info.
Posted on Jan 08, 2015
sandrew
  • 2961 Answers
SOURCE: setting up a new hard disk and operating system on an Acer Power SC
There should be more than one disk, as the other will be drivers, all you need to do is press F2 or Del to get into your pc's bios settings and change the first boot device to your cd drive, insert your acer disc into the drive, then save the bios settings, restart the pc ,then, when prompted on screen to press enter to boot from cd; do so.
You should then follow instructions to set up windows on the 'C' drive as is default and it may need to reformat in NTFS.
Posted on Sep 08, 2008
mulmol
  • 184 Answers
SOURCE: Acer Power FH will not boot Windows XP Pro
Well your explanation was clear but your should've not ruled out the hardware issue. if both computer suffered the same problem at the same time the problem could be within the Desktop itself. I have experienced the same problem with my HP when I move to my new house after 5 years. What happend is that during transportation the vibration lossened up the parts inside your computer. So what I did was I reseated all the parts inside the desktop and reinstalled Windows XP. Till now I have never had any problems yet.
Posted on Mar 26, 2009
heavyice
  • 374 Answers
SOURCE: I shut computer after windows updates and now it won't power up
1.Try booting into safe mode (F8 on startup) and then uninstall the update or you can run system restore. 2.try going to the advanced boot options and choose "Last known good configuration" 3.The last option is 'to do a repair install' if you have a Windows XP CD you can just do a repair of the OS.
Posted on Jul 16, 2009
drcspy
  • 10 Answers
SOURCE: Acer M3100 crashed
I'd suggest there is a possible hardware error. You need to get into the bios and check the temperatures they'll be under 'system health' or similar. Also might be worth running a ram check. Download 'windiag' it's a microsoft program designed to check your ram and it is very good.
Posted on Sep 03, 2009
ProsunPal
  • 60 Answers
SOURCE: I have upgrded my Acer Aspire T-180 from Vista
You do not have any support on that PC anymore. You have void the warranty.
Posted on Dec 30, 2009
My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 18, 2012 | Acer Black AX3400G-U4802 Desktop PC with...
My acer desktop has been hanging all of a sudden. When i restart the desktop,it takes about an hour for it to reach the home screen and another hour for the home screen to load. When i try clicking on the...
the hard disk on your pc is almost worn out.
you will need new hard disk. Install fresh copy of operating system and loading to home screen will be normal again.
Jan 09, 2011 | Acer AX3950-B3062 Desktop with P206H...
Hi dear, I have one acer veriton 7600gt desktop computer at my home, last night i working that pc suddenly its shut down and when i again start the pc one blue screen is coming and my hard disk is...
looks like old xp machine. power supply could be flaky,bad caps on the board,dust build up on the cpu fan or graphics card causing it to over heat and shut down
Jul 08, 2017 | Acer Veriton 7600GT PC Desktop
Computer did not power up after re-imaging
remove your RAM and processor.......then turn on ur PC...it will gave you different beeps...then again install ur RAM and processor... ur problem will solved
Mar 09, 2009 | Computers & Internet
Computer turns on then immediately shuts down
Check Ram first try changing it other wise ur Mother board is giving fault try ram first try re installing it , check the power as well
Feb 20, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Acer shuts off when its turned on it loads sometimes but most of the time shuts off before it starts windows
Are you talking about the boot screen that shows WinXp forst and either reboots or shuts.......this is important now can you explain because if itis the boot screen then its only a software problem. The last person who had this problem after I gave him the solution was never to be seen again I imagine it worked? he didnt even say thanks.
Oct 04, 2007 | Acer Aspire 5100-5022 Notebook
Acer Veriton 7600GT PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
