Question about Sony DAV-C990 System
I'm able to load the DVD/CD, the display say "reading", the play sign appear but nothing happend, neither sound nor imige come out. I've had the equipment since 2004 and I never this problem before. I would appreciate any idea about it you can give me, thanks.
  • Sony Master
  • 17,129 Answers
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Apr 09, 2011
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
"No disc" message while CD is in
either a dirty or bad optical pickup in the unit that reads the disc so it can play.
Jun 15, 2012 | Cambridge Audio Sonata DV30 Player
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
Jul 28, 2011 | Pioneer PD-F906 100-Disc CD Changer
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
My unit is a DVP3140, purchased 2006 or 2007. As soon as I got it, I changed the code to region 0 so that I could play the DVDs I bought when I lived in Italy. It worked great for about 3.5 years of...
By changing to Region 0 you've changed the Laser control and subsequently the Laser is failing earlier than it would have done under normal operation.
The only solution would be to replace the Laser which is not normally cost effective and often unavailable anyway.
CDs may still play for a period of time as these require less power as there isn't as much information to read as a DVD.
May 29, 2011 | Philips DVP3140
I have a Panasonic DMREX78 DVD Recorder..I was trying to copy something from the hard drive to a disc and it froze...I can turn it off and back on and it sounds like its trying to eject but nothing...
sorry, no solution from me, but you are not alone! I have a similar problem with my DMR-EX78. I tried to copy a HD recording to DVD in Dec, it failed and ever since I haven't been able to play DVDs or CDs (comes up with 'cannot read - check DVD/CD' and the red circle with a red line through it symbol appears in top right corner. A 'D' sign has appeared on the display and the unit now takes a lot longer (one minute) to start up (power mode is set to same as was before). Will be interested to see what solutions are put forward for your issue.
Jan 02, 2011 | Panasonic Televison & Video
Sony DAV-C990 System Logo
60 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
