Question about ASUS P5KPL-AM/PS Motherboard
Hello experts, i have asus p5kpl-am/ps motherboard and i want to install front panel of power button and all (not usb panel), i don't have booklet and don't know how to put cables in series or +ve -ve way, please help me.
    Problem Solver:
  • 17 Answers
Look at your front panel pins there is a written instruction there where to put the wires use a flash light to see it clearely
Posted on Oct 22, 2011
  • 1,027 Answers
On this page:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%2fPS&p=1&s=22
Select your operating system and you wil redirected to the download page for your motherboard.
You can download the user manual and the drivers.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Posted on Apr 09, 2011
  • amarjeet Oct 22, 2011
    hello frnd, please tell me how to recognize what cable will fix in what pin,. i mean, power button, reset button and led's of hard drive and power have different cables and have to insert in a particular manner in any motherboard, as much i knw, in coloured and white cable couples... so, i want to know what cable is +ve and which 1 is -ve and how to make a series... and will there any problem occur if i fix them in wrong way.. this is my question... if u can help me, i will be very much thankful to you friend.
  • eric
    eric Oct 23, 2011
    every cable in the power button has a marking on it. Rw for reset switch PW for power P led for power led HDD led. SPR or SPK for speaker all colored wires are + and all white are - .... now look closely to the front panel pins on *********** board you will the same making on your wire. some board marking are written in 2 row. the top row indicate the upper pin 2 row is for lower pins and it is separated by white line' this line tells you how to put your wire ( horizontal or vertical ) You can put reset and power in any way you like as long as you put it in the correct pins (no particulars for + & -) now on the HDD and Power led you could also see the marking of + & - or sometimes you can see it where the pin is planted..............
    i hope you understand my instruction ........... good luck
    tell me if this post help you
Windows 8 not supported asus p5kpl am ps motherbord drive
The Asus p5kpl am motherboard will run windows 8. There are no drivers for windows 8 at the Asus site yet, but if you need drivers after the install, you can try the windows 7 drivers.
Drivers can be found here :
http://www.asus.com/Motherboard/P5KPLAM/#support_Download
Jan 14, 2013 | ASUS P5KPL-AM/PS Motherboard
ASUS P5KPL-AM/PS
If there is no power getting to the motherboard check to make sure power module is working, if okay! motherboard has major issues and will probably need replacement.
Mar 10, 2012 | ASUS P5KPL-AM/PS Motherboard
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
P5KPL-AM/PS AUDIO DRIVER I WANT THAT DRIVE NW
Hello, you can download the driver here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM&p=1&s=22
Please select your windows version.
Select audio and click on global for download.
Unzip the file before installation.
Oct 08, 2011 | ASUS P5KPL-AM SE Motherboard
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
How to activate front panel audio for P5KPL-AM SE?
you connect your front panel cables to to the motherboards front panel connectors to activate the front panel audio.
for more reference you can download your motherboard manual in Asus website below
http://support.asus.com/download/download.aspx
Feb 02, 2011 | ASUS P5KPL-AM SE Motherboard
It is same for my P5KPL AM/PS front pannel is not working for this mainboard. My OS is windowdow xp 7
For that you need to check the front panel connection to motherboard. You can see diagram below . Click here Download manual from below link then connect front panel connection to motherboard. You can also find the diagram on motherboard there are some pins on corner of the motherboard where you need to terminate front panel connection. You can read diagram near those pins. Let me know if you need further assistance. Thanks for using FixYa.
Nov 28, 2010 | ASUS P5KPL-AM SE Motherboard
I have P5KPL-AM/PS motherboard. How can i activate my audio front pannel
First of all check if your front panel is connected via cables to motherboard. I am biding that is not connected.
Oct 30, 2010 | ASUS P5KPL-AM SE Motherboard
Hello,My system now shows a message "USB Over
Try to start the computer in Safe mode. If it works there then open the Device manger and uninstall all the USB hub controllers and then restart the computer. Also undo any hardware changes that you might have made to the computer just before you started getting this problem.
Thanks. If this was helpful then kindly rate me.
Oct 28, 2010 | ASUS P5KPL-AM SE Motherboard
ASUS P5KPL-AM/PS Motherboard Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
