Question about Dishwashers
Water not drainig away - Dishwashers
  • 17,129 Answers
Check the voltage on the drain pump/valve when the program comes to the drain cycle. if present then the pump/valve must work to drain off the water. If so remove the pump , back-flush and clean. If faulty you must replace.
if voltage is not present then the program controller unit is faulty and needs a check as there is no output to work the pump/valve.
Posted on Apr 09, 2011
Water keeps drainig
Follow this link to Washing Machine Repair manuals:
http://www.appliancerepair.net/washing-machines-forward.html
It's saved me a bunch of $$$'s on washing machine repair
Feb 16, 2013 | Roper Washing Machines
Why is my floor on the right site (passenger sit) always soaked?
Your aircondition drain duct tube is not attached so instead of drainig on the outside its going inside. you need to pull the rug on the passenger side away to acces this tube just reattach it and make sure it drains on the outside
Feb 24, 2012 | 2006 Kia Optima
The water is not coming out of the clothes
Hiya,
2 simple checks for you with this problem often when there is excess water left in your cloths after a wash its due to a reduction in the outlet (waist) so i would surgest checking the waist pipe & drainige connections for excess lint as this can reduce the amount of water getting out & leaving it in your cloths or machine.
Hope this helps
Apr 23, 2010 | Kenmore HE2 Plus Front Load Washer
My washer has a little water left in the bottom of the drum and the washer has a smell of mildew. The pump is pumping great but isn't finishing the job. What would be the problem?
Hiya,
sometimes you can get a buildup of lint in the drainige system try checking the waist pipe & drainige pipes if you have a build up of lent in them or if the waist pipe is pushed to far down a drainige this can reduce the amount of water escaping & leave it in your machine or cloths the smell would be a sign of old water so those would be my surgestions to try & soilve this problem.
Hope this helps
Apr 23, 2010 | Washing Machines
Hotpoint - Drainig Issue
if you have a garberater you need to remove the drain pipe and clean out
Feb 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My Hoover Nexta washing machine is not drainig water
First empty machine by lowering waste pipe into a large bowl or bucket. Then remove kick plate from bottom front & you will see the filter. this will have a small screw which needs to be loosened then unscrew filter and check for coins etc.If this does not fix come back for other options.
Nov 20, 2008 | Hoover Washing Machines
Wont spin
If your washer pumps out but then the motor attempts to start repeatedly and rapidly, you have a bad motor. Please don't rate this, as anything but a FixYa drops my rating.
Oct 28, 2008 | GE WBSR3140DW Top Load Washer
Ruud central air system
Install a condensate pump if you don't have one. Check to make sure it works if you have one and clean it out.
Jun 08, 2008 | Ruud Central System Air Conditioner
Miele 24" incognito
if it is draining and not drainig all the water out I think you can increase your drain time.Also check to see if drain hose has fallen make sure it is tied to under counter top.
Nov 21, 2007 | Miele 24 in. G646SC Plus Free-Standing...
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
Owen Barnes
