Question about Technics SL-1200MK2 Turntable
The record keeps sticking in same place iv adjusted the hight weight and anti skate i know its not the carts or needles cos iv swapped those its been suggested to me tht the arm is damaged or bent even ???
    Champion:
  • Technics Expert
  • 271 Answers
Hi, have you tried manually moving the tonearm (with tt off) from its stating position across the platter to the centre? If you do this and find you get resistance at a certain point then there is damage to the tone arm base or bearings. Is the tonearm lifter going down completely?
Posted on Apr 27, 2011
Needle skips along records.
3 causes
1. Bad stylus.
2. Not enough weight - adjust weight on end of arm, or turn knob with numbers up slowly bit by bit, trying a record each time till it stops but doesn't "rumble".
3. Adjust anti-skate control if it's got one. Again bit by bit, testing with record.
Aug 28, 2011 | Sony Audio Players & Recorders
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Feb 15, 2011 | Kenwood KD-291RC Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Needle Skates
If you're a real DJ then the Technics is the best TT to scratch on. Don't listen to that fool about not scratching, lol. Your tone arm could be the problem. Have it checked out. I repair TT's
Mar 18, 2009 | Technics SL-1210 Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
Technics SL-1200MK2 Turntable Logo
113 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
