Question about Garden
Switches off every few mins, then starts again
I had a similar problem with a motorcycle. In that case, the problem was rectified after a loose/partially broken wire from the battery (assuming that your mower is similarly equipped) was replaced. At any rate, it sounds electrical to me, though you might also check your air filter to see if that is clogged, thus starving the engine of O2 and causing it to stall, though in that case, it likely wouldn't easily start up again without a long pause.
Posted on Apr 09, 2011
How do I fix my forced air heater?
Check for sensors on the unit that might be failing. I think many heaters have safety interlock switches on them now.
Overheating... Too Hot
Position Sensor... Knock it over & it turns off.
Loose wires....
Obviously turn it off when looking inside
Good Luck
Feb 21, 2015 | Heating & Cooling
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Karcher wont start
there is a pressure switch in those machines that goes bad. it is a common problem. if its under warranty let them work on it. if not take it apart and you will see the problem. it is replaceable and you can do it.
Mar 28, 2014 | Garden
Car will not start- will crank- anti-theft light flashes - turn switch to on for 10 min. when light stops flashing - turn switch to off - then it will start. Changed to a new switch - worked or started for...
try a diffrent key,your extra one.Could be the micro-chip inside is not comunication with anti-theft-.This happened to me.I used the spare set for a few days .then the other key started working again
Jun 28, 2011 | 2004 Chevrolet Malibu
Runs for a few minutes then switches off
there is a relay just inside the control panel at the front ,
it allows the mchine to rotate in both directions
by replacing this it should cure the problem
Jan 23, 2009 | Hotpoint TDC32 Electric Dryer
Tumble dryer
You may have loose wires.
Check the door switch first.
Then check the wires going to it by opening the top or front of the machine, which ever opens to examine the switch and wires.
Also, check this link.........
http://www.howstuffworks.com
Let me know if you have the problem solved please.
Thanks,
yalmer
Mar 13, 2008 | Dryers
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
