Question about Whirlpool Duet GHW9150P Front Load Washer
I cleaned the strainer, checked all the hoses, but still got the F-21. Checked the pump no objects inside. Still got the F-21. Checked the pump again and found the impeller does not spin freely. Is this supposed to happen.
  • 3 Answers
I have the same problem: new drain pump, impeller needs to be "kicked" to start reciprocating (which, of course, is not possible once installed). Drain pump is listed as 50 Hz (UK), though I am in US (60 Hz) - could that make any difference?
Posted on Jul 17, 2011
A WASHER THAT DOESNT DRAIN WATER ?
The pump housing could be clogged with food. You can sometimes Access the strainer from inside the dishwasher. If that looks ok you will need to look at pump below by removing the hose clamps and checking the pump intake. If all that looks good you could have a bad solenoid or pump.
Dec 28, 2014 | General Electric WHDSR316G Top Load Washer
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
Water wont drain from machine and move to next cycle
Inside the hose from the tub to the pump is a mesh screen or filter cup which protects objects from getting into the pump. With time the screen gets totally clogged. Yank out that hose and clean out that strainer.
Dec 14, 2010 | Electrolux Washing Machines
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Flashing f- 21
F21 means “long drain” – takes too much time for the water to get out. Check the drain hose and make sure it is not clogged or kinked. Check the drain pump filter for foreign objects. Check the electrical connections to the pump and make sure the pump is running. Check for foreign objects inside the pump. If it doesn’t help, replace the pump. To clear the display press PAUSE/CANCEL two times. Good luck.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not pump out water
There are two things that you can do that will help:
1. Clean your strainer. It is located between the drum and the pump, very low in the washer. If yours is a front loader, it's behind the kick panel and is located between the drum and the pump. The strainer is connected to the drum with a rubber hose. Unscrew the strainer, and clean it (caution, water!). Look up into the pump and remove any debris that has made it past the strainer.
2. Dump the contents of your drain hose (the one that goes to the wall drain) into a bucket. If possible, run an empty load with your hose pointed outside.
Best regards, --W/D--
Aug 08, 2009 | Washing Machines
F02 with good pump and clear filter... now what?
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^%#$
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NO START BENZ 190D
Hello I'm an M.B. tech.. It sounds like the fuel strainer is clogged. It is a very common problem on M.B. diesel engines of that era. Diesel fuel develops algea inside the fuel tank and after a period of time it clos the strainer. The strainer is at the bottom of the fuel tank where the big fuel hose attatches to the tank. The hose unscrews frome the strainer and then the strainer unscrews from the tank. There is a filter on the strainer that can be cleaned and reinstalled. In the engine compartment there is a small primer pump that is by the fuel rack inline with the feed hose from the tank. If you turn the knob(clear or white plastic) on the pump it will retract allowing you to use it as a hand pump. If when attempting to retract hand pump it is sucked back down and will not stay retracted that means you have a restriction in the line- your fuel strainer is clogged is the most likley problem. replace both fuel filters during repair for best results. Good Luck
Apr 14, 2009 | 1988 Mercedes-Benz 190
Asko W660 Quattro Front Load Washer - WATER INLET FAULT. Checked the troubleshooting guide, which recommends disconnecting the hose and cleaning the strainer in the water inlet of the machine. WHERE IS THE...
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Aug 28, 2008 | Asko Washing Machines
F 21 fault ?? on a kenmore mod 110.47512601
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Feb 17, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
