Question about Hotpoint Aquarius WF000 Front Load Washer
Wf000 i seem to be geting water dipping from the bottom front of my washing maching it only seem to happen when the rinse & spin is in action can any body help
  • kinkykee123 Aug 24, 2008
    i have cleaned the filter out and its still doing it the filter is at the back of the washing machien hope this helps
I have the same problem & i think its the filter, it may need cleaning out but i dont know where it is! can anyone help me locate it please
Posted on Aug 23, 2008
Will not drain the water
The most common cause is a foreign object caught in the pump keeping the little impeller from spinning. Take off the pump hose and make sure it is not plugged.
Mar 14, 2012 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Does not heat water
the heater element has probably gone faulty or the thermostst is faulty, they sould come as one replacement.
Apr 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washer not rinsing
If it is at the rinse or spin cycle it could be something trapped in the pump, for the water can't drain quickly enough when the machine starts to spin & the water gets forced back up through the soap dispenser as there is nowhere else for it to go. Check your filter too.
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
80 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
