MACHINE NOT HOLDING WATER - Washing Machines
Water in the holding well, no water is coming through to the coffee capsules or into cup. The machine power light is on but nothing is happening.
I have heard of this problem with another brand of machine and what it turned out to be is a back flow valve made of plastic getting clogged up. These valves are for keeping the coffee water from backing up from the coffee capsules back into the holding well water. These valves are rather inexpensive but getting to them is a pain. My friend contacted the company that made his and they were aware of the problem and sent him a brand new machine and told him to destroy the old one. This is how we became aware of this problem was by taking it apart. We found the valve, cleaned it up with vinegar to get rid of water deposits, and reinstalled it. It has been working great ever since.
May 02, 2011 | Nespresso D150 Espresso Machine
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
How do you replace the mixing valve on a kenmore series 80
Water Inlet (Mixing) Valve Replacement Procedure
  2. Shut off the water supply valve.
  3. Place a bucket or pan under the water inlet valve to catch residual water from the fill hoses.
  4. Remove the fill hoses from the water inlet valve then drain the residual water into the bucket or pan.
  5. Remove the screws holding the console at the back of the machine. On some models, the screws are hidden under the console's removable end caps. To remove, pull the top of the end caps to the front of the machine. On some models, the console is secured to the machine by clips under the front corners of the console. Use a putty knife and insert it's blade under the front corners of the console then push it until the clips are released.
  6. Lift the console then flip it towards the back of the machine.
  7. Disconnect the lid switch wiring harness connector from the body of the machine.
  8. Lift the lid, grab the front rim of the cabinet, not the tub, then rock the cabinet to the front of the machine and pull it all the way.
  9. Remove the screws holding the water inlet valve to the back of the machine.
  10. Move the clamp holding the inlet hose to the water inlet valve to remove it.
  11. Install the new water inlet valve and reassemble the cabinet and the console in reverse of the disassembly steps given above.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
Thw washer fills with water when off
The inlet valve is faulty and you have to replace it. It is located on the right side of the machine viewed from the rear where the fill hoses are attached to.Turn-off the water supply, unplug the machine and do the following:
  1. Remove the three screws holding the top panel in place.
  2. Disconnect the hoses and electrical connections to the water inlet valve.
  3. Remove the mounting screws holding the water inlet valve.
  4. Reinstall the replacement valve.
  5. Reinstall the hoses and the electrical connections.
Replacement valve part number for Whirlpool Duet GHW9150P front load washer is 906483.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
Water gets hot but doesnt pull water to grounds
Hope this helps.
May 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Simpsom Washing Machine
First see that the exit hose behind the machine is at the correct height, before coming down into the wall standpipe or your sink. Your machine pump pumps water over this height, about 2.75 feet above ground level. Possible there is a water level height marked behind your machine.
If water flows out when machine is off, possible your inlet valve at top of machine is defective...............can be replaced easily.
Mar 22, 2008 | Washing Machines
Machine not holding water
Your exit pipe behind the machine could be level into the drain, that is at floor level. The machine has a water level where the pipe must bend over (about 3 feet from ground level); it then passes into the drain in your wall, also raised. Your water exit pump pumps the waste water of the machine OVER this height. Check this out.
Dec 14, 2007 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
