Question about Kitchen Ranges
Ge arctica side by side. Freezer not freezing refrigerator not cooling
  • Kitchen Ranges Master
  • 6,993 Answers
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Posted on Apr 09, 2011
Veg and fruits freeze up.. Why? and what should temps be for frig and freezer?
We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: http://fixitnow.com/wp/2007/12/06/ge-side-by-side-refrigerator-freezing-the-beer/. You also might need to enter a diagnostic code when you replace it. Check this out also:
http://fixitnow.com/wp/2009/10/02/activating-self-diagnostic-mode-in-a-ge-arctica-refrigerator/. Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
Jun 14, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
I have a GE Profile Arctica (2005 model) side by side. Model # PSS26MGPABB. The freezer is not getting cold enough (to freeze bread for eg), and the ice maker has stopped making ice (the water is not...
This could be a fan motor problem. Check to see if the fans are running and if not take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the compressor is not running this page will help http://appliance-repair-it.com/GErefrigeratorrepair.html
There could be a defrost problem, look on the back wall of the freezer to see if it is covered with heavy frost. If so your problem is that it is not defrosting. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
Sep 20, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator freezes items in the rear and there is frozen water on the bottom of the freezer section directly underneath the ice maker
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | GE Profile Arctica Stainless Steel Top...
GE Arctica Refrifgerator- Not cooling
its either the ptc overload on the units compressor is bad and is easily replaced by unplugging the old and replacing with a new replacement,the only other thing it may be is the cold control for setting the temp of the freezer/refrigerator,but normally these don't go out
May 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Not freezing or cooling
You will need to remove the cover in the freezer section, if the fan is not turning, you will have to replace the fan motor, this what allows the cool air to circulate and cool the refrigerator.
Nov 10, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
Kitchen Ranges Logo
207 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
