Question about Bosch Classixx WFL 2066 Front Load Washer
I have a small leak coming from under my machine that I noticed at the end of the cycle on emptying my machine. Could this be a problem with my filter?
  • Bosch Master
  • 17,129 Answers
Any leak can be easily identified only if you can take a closer look with a good observation lamp.
So this can be from a faulty hose connector, a faulty hose, faulty drain pump/valve, drum gaskets- door gaskets or the inlet valve.
Once this is confirmed you can replace the gaskets or tighten the hose or clean the drain valve/pump.
Posted on Apr 09, 2011
Dishwasher not emptying, and leaking water every where
A very frustrating issue to be sure and these questions are not meant to be flippant but I do want to find out if there is actually more than one problem. Does your machine have water leaking even when it is not turned on? You mention that the dishwasher is not emptying - do you simply mean is it not emptying properly?
If water is coming out when the machine is not on, it means you have a leak at the water supply connection that only stops when you turn the water valve off. If the machine fills and immediately starts leaking water during the wash cycle, it means there is a gravity leak usually near the pump. If the water only leaks when the machine should be draining it, it means you have a leak somewhere in the drain line - a not uncommon problem. I've seen several instances where mice have chewed a small hole in the plastic drain line to get the water.
Can you give more specifics about when the water is coming out? Also, your make and model number would be helpful.
Apr 05, 2016 | Dishwashers
Noticing a small amount of water coming from under my washer durning a wash cycle.
the only way to tell is to get in there and take a look,it could be leaking from the pump,bad tub seals,is it noisy at all in the spin cycle,if so that's one way of telling it's the tub seals,could be leaking from a hose.watch this video,it will show you how to get the frame off so you can see where the leak is.hope this helps you out......http://www.youtube.com/watch?v=vogysB7XOc8.........copy and paste
Apr 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking from under washer
your rinse hose has a hole in it or has come loose from the pump
Sep 21, 2009 | LG WM0642H Front Load
Older Kitchenaid Dishwasher doesn't fully drain and smells
Hi Jay. Remove the lower front panel and you will see the drain hose. On the machine end of the drain hose is a small drain pump. Disconnect the hose and the pump and you will most likely find a partial blockage in the form of a piece of glass or something preventing a total drain.
please mark this answer as a fixya!
Mar 09, 2009 | Dishwashers
Leak where water enters drum
I would say you havda inlet valve. With the washer not in use and empty after about 2-4 hours do you notice that you have a semi full tub? If it is filling with water by itself you have a bad inlet valve all you have to do is take the top panel off you will see the valve it's what is attached to the fill hoses. When you have dirty lines the dirt goes through the solinoids and keeps them open causeing the water to come in when not in use.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Kenmore washer leak
With the machine unplugged and EMPTY disconnect the water and waster water connection from the wall and tip it forward you should then be able to access the pump.  Check the hoses running to the pump. (usually white plastic with 2 large and 1 small hose running to it.. you can also just move it away from the wall with it completely connected and run it thru a cycle to see where it is leaking from.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Leaks
Possible the leak comes from under the tub. Remove the wall plug & take off the rear panel. Check to see if the hose from the under the tub is secure, it could be the grip clip below the hose has come off. This is where it connects to the pump section. You need a grip plier or something to get it back on securely. If this is not the case take a good look to see where the leak comes from.
Next is the door gasket, maybe a tear.
Nov 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
