Question about Sony VAIO VGP-WKB1 Keyboard
Left click button on sony vaio not working properly, how can i fix it or what do i need to do? can i remove the left click button on its own and clean it, or would i need to remove the whole keyboard? thanks.
joecoolvette
  • 5660 Answers
SOURCE: the left click on my sony vaio nr series notebook
Underneath the button covers for the mouse, are miniature momentary contact switches.
View the 6th photo down on this page,
http://computer.howstuffworks.com/mouse2.htm
The two square shaped objects with the shiny metal covers, and a Black round dot in the center, are the miniature momentary contact switches, that I'm referring to.
(One on each side. The one on the right, has two silver colored Resistors to the left of it. The one on the left, has an Orange colored Solid Capacitor to the left of it. They are both right below an Integrated Circuit. {IC}
[Granted this is a Ball Mouse, but it shows the miniature momentary contact switches used for all mouse]
If you popped that square metal cover off, you would find that the Black round dot is a plastic piece. This is the part that moves up and down, as you press each individual mouse button. Under that Black plastic part is a small, thin, part made of spring steel.
It works like a diaphragm. It is concave shaped, with the curve going up. As you press the mouse button down, the Black plastic part moves down, which in turn flattens out that concave spring steel piece.
The outside edges of the metal spring steel 'diaphragm', touch a Negative connection.
When the center of the spring steel diaphragm flattens out, it's center touches a Positive contact.
The miniature switch now makes a complete circuit. It's a Momentary Switch, in that once you release the pressure off of the mouse button, the switch is Off.
All the things you wanted to know, huh? lol!
Point of this breakdown, is that if the spring steel diaphragm receives too much pressure over an extended period, it loses it's
'spring'.
Way to fix it?
Replace that miniature momentary contact switch.
Logical solution?
Replace the mouse.
Posted on Aug 14, 2009
  • 52 Answers
SOURCE: Replacing Keyboard Sony VGN-N130G
http://www.notebooks-driver.com/
Posted on Oct 10, 2008
Joed911
  • 4338 Answers
SOURCE: sony vaio mouse won't go left
Computer mouse are inexpensive. And can be found in any office supply store, even Wal-mart.
You can use the HP or any generic 2 button, scroll ,USB or PS2 mouse on this unit.
Your Sony mouse is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 05, 2008
  • 20 Answers
SOURCE: Sony Viao keyboard - certain keys got wet & no longer work
well the damage is pretty much already done however you may try dabbing your keyboard with alcohol you can use quite a substantial amount use Que tips to get in between the keys.
I suggest getting it fixed
Posted on Dec 15, 2008
  • 32 Answers
SOURCE: Keyboard shortcut buttons not working
You must have received a Cd with your Sony Vaio model, u need to install th e software again.
Posted on Feb 11, 2009
In my VAIO VGN-CR12GH/B in built motion eye camera is not functioning. please help my friends.?
we need to determain if your camera is still installed properly. Click the start button now just above it you will see a rectangle search box in that type device manager click enter now in that list you need to find your camera (Imaging Device) & see if it's installed. if there is a arrow next to it this means there is something wrong possibly uninstalled or needs a driver update, so right click on it then left click on update driver hopfully that helps
Apr 20, 2014 | Sony VAIO VGN-FJ270/B Notebook
Reinsstall scan to e-mail
Your Sony Vaio laptop comes with a restore section pre-installed that allows you to revert the operating system's settings to an earlier date.
The restore feature is useful if your Sony Vaio has been infected with a virus or some of your hardware is no longer working properly.
If you don't want to search through all of your various settings and registry values to locate the source of the problem, an easier solution is to simply load a restore point.
Close any programs that are currently running.
Open the "Start" menu and click "All Programs."
Select "VAIO Recovery Wizard." Click "Next."
Navigate to "Media and Recovery Options" and click "Proceed with System Recovery."
Select "Next."
Click "Recovery Options," and then choose "Custom Recovery."
Click "Next," and then select "Windows System Restore."
Click "Next" and then "OK."
Click the left and right arrow buttons above the calendar to navigate to a restore point you want to load.
Click the specific restore date you want to use for your Sony Vaio laptop.
Click "Next," and then click "Confirm Restore Point Selection."
Nov 26, 2013 | Sony VAIO Computers & Internet
Scan document
Use the system restore utility to an earler time when it was installed hopefully you can recover it using it.
Select "Next."
My left button on the mouse pad wouldn't work
try to tap on the touchscreen instead of the left click
Mar 07, 2013 | Sony VAIO Notebook
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
I have a Sony Vaio VGN CS290. Just a few minutes ago the touchpad and the buttons were working properly. However, I suddenly cannot make a click/double click from both the touchpad and the left click...
This sounds like a hardware issue, however, you can do some troubleshooting steps:
First solution: Go to the mouse settings.
On the "buttons" tab, go to the "double click speed" area.
Slide the cursor all the way to fast and try clicking on the folder with your left mouse button,
If it opens easily, your button should be working.
If not, try sliding cursor all the way to slow.
Second solution: Download the latest touchpad driver from Sony Vaio website support drivers page and type in your laptop serial number and try to reinstall the touchpad pointer driver and restart the system.
Third solution: please perform a system restore, how to perform a system restore press and hold down the windows key on your keyboard and press the R key after that a window will pop up, in that command box type "rstrui" without colon and you will see the system restore page click next and you will see several dates, now select the date where your computer was working fine and then click next and proceed with the system restore, please note that system restore will not delete any data or files but it will uninstall only the programmes which you have installed on or after the date which you have selected to restore.
If none of these works try connecting a mouse and see if all the clicks are working fine and if that is working fine then it has something to do with the hardware of the click button of the laptop I would suggest you to take it to the service center and get it replaced it won't cost much.
Aug 27, 2017 | Sony 4-660-223-01 Touchpad Keyboard
Left button of vaio mouse does not work anymore. any idea how to fix it? thank you!
Try the mouse in a different computer.
If it works, it's the "settings" for the mouse in your copy of Windows that have changed, i.e., pushing the LEFT mouse button is *NOT* "associated" with any specific "action".
Or, shutdown your computer.
Disconnect the mouse from the computer.
Flip the mouse over.
Look for any screws holding the mouse together.
If you find some, undo the screws, and split the mouse apart.
Inspect the mechanism that "clicks" when you push the LEFT mouse-button.
Remove any dirt/dust.
Reassemble the mouse.
Reconnect it to your computer.
Try it.
If it still does not work, try the mouse in a different computer.
If it still does not work, responsibly recycle it, and buy a new mouse.
Oct 20, 2010 | Sony VAIO VGP-WKB1 Keyboard
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Malfunction of the left button of the touch pad
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .Hey it's a Cheap laptop and uses cheap parts.
Jan 08, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Sony VAIO VGP-WKB1 Keyboard Logo
848 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
