Replacement of MCU Kenmore Elite Washer
F11 on our Kenmore Elite Washer. MCU failure diagnosed. Any tips on replacing it ourselvelves? Is this an easy repair that the average do-it-yourselfer can accomplish on their own? Will try to order online, since we are hardly at home and not so easy to schedule someone to repair.
Kenmore Elite HE3t Front-Loading Automatic Washer Model 110.4996
SOURCE:
  • 1314 Answers
SOURCE: Need to purchase CCU for Kenmore Elite 45966 Front Load Washer
try here http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jan 11, 2008
the dr
  • 447 Answers
SOURCE: Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Posted on Jan 24, 2008
  • 1314 Answers
SOURCE: HE3t front door
send my an e mail at [email protected] and my four boxes lol ill help ok job aid too big to send here
Posted on Mar 02, 2008
  • 1028 Answers
SOURCE: I keep getting an F11
probably main control bd ..remove top ..rear support small box with all the wires ck for loose connection first..no tool other that a torx tip driver to remove top and a small screwdriver to help in removing clips holding wires in code means communication error
Posted on Sep 09, 2008
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Posted on Jul 13, 2010
Kenmore elite E3t F11 error code
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. See images below. Key #13 is the CCU and key #1 is the MCU.
The CCU (Central Control Unit) is located under the top along the side panel.
I recommend checking for loose wire connections at the MCU, CCU and motor. If you do not get any motor action at all, the MCU has likely failed.NOTE: Disconnect the power cord from the power source before removing the top and lower access panel. I recommend calling a service technician to diagnose and repair your washer.
Parts can be looked up and ordered at Sears PartsDirect
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services .
Dec 16, 2012 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Washer code F11??? I have a Kenmore Elite front loader
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 22, 2011 | Kenmore Washing Machines
Flashing f11 code in spin cycle. meed a manual for the He 4t. have also seen a dl code once.
The F11 error code indicates an internal failure of the MCU (Motor Control Unit). Most often the MCU will need to be replaced; however there are a few things you may want to check first. If you have a volt/ohm meter and are comfortable working around live electricity I can give you a few checks that will help you diagnose the problem.
I have included an illustrated set of instructions, that should guide you through the disassembly and testing for the F11 (see this image).
Check the wiring harnesses between the CCU (Central Control Unit) and the MCU, and between the MCU and motor. If these connections are not good there can be a loss of communication between the computer boards and the motor.
Check continuity of the motor windings and tachometer. Begin by Ohming the set of 5 black wires (this connection also has a green wire) at the MCU. They are numbered from top to bottom 1-5, with 1 being the top black wire.
Ohm 1 to 2, 1 to 3, and 2 to 3, then Ohm 4 to 5. Wires 1, 2, and 3 should read approximately 6 Ohms when Ohmed two at a time, 4 and 5 should read approximately 115 Ohms together. If the readings you get are not close to 6 (5 - 7) and 115 (110 -125) the motor is bad and needs to be replaced.
If the Ohm readings are close to those given, and the wires and connectors are good, replace the MCU.
Jan 09, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Stops washing mid cycle flashes f11
Here is what the manufacture says about this error code followed by my comments.
What to do:
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Phil's comments ---------->
This error usually indicates a failure of the circuit board that controls the motor. It is a repair I would suggest leaving to a professional as it can be tricky to diagnose the problem
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kemore Elite washer keeps stoping and displaying an error message of f11. We have to unplug it, or sometimes we can push a bunch of random buttons and that can unstick it! Its very frustrating......any...
1. Unplug washer or disconnect from power.
2. Check wire harness between drive motor and MCU. Between MCU and CCU. Check the motor and do a continuity test.
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
6. Replace the MCU board.
Jan 30, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
294 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
