Question about Toshiba e330 Pocket PC
My toshiba pocket c e350 gets stuck at align screen
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
Toshiba pocket pc my pc is not finding the usb
Have you check your USB cable? I think your USB cable was crashed!
Mar 14, 2010 | Toshiba e350 Pocket PC
How can I install a dictionary for my Toshiba e359 Pocket PC?
dictionary downloads for toshiba phones can be found at www.getjar.com
Feb 12, 2010 | Toshiba e350 Pocket PC
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
Toshiba e350 Pocket PC Charger lost
Does it charge if you connect it to a pc with a USbcable
Mar 22, 2009 | Computers & Internet
Align screen
i have the same problem wat to do i am stuck wit align..
Aug 13, 2008 | i-mate PDAL Pocket PC
Toshiba Touch Screen does not work
Hi This may help you :: Select , Settings, System tab, Align Screen to adjust the touch screen. If the screen alignment loses calibration it may not be possible to adjust alignment using the above method. Also, here is a link that may help :: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuals-userguides-su530093-ppce400ug20030916pdf&sliceId=pdfPage_113&dialogID=6730022&stateId=1%200%206728267
Apr 30, 2007 | Toshiba e740 Pocket PC
Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
Sep 11, 2005 | Toshiba e355 Pocket PC
E350 ROM-image update?
I have looked at different sites and found some informations. The only way for you is an EUU (End User Update) but Toshiba doesn't offer an EUU for the e350 until now, perhaps Toshiba installed a OS with all available EUUs yet and is waiting for an EUU from MS.
Sep 11, 2005 | Toshiba e350 Pocket PC
Wi-Fi on an e350
I am not sure but I think that e350 do not support Wi-Fi connection. As far as I know it works with Bluetooth SD card.
Toshiba e330 Pocket PC Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
