Question about Admiral AW22 Top Load Washer
Admiral AW20 Top load washing machine
I have a Admiral AW20 Top load wwshing machine that was just moved from one house to another, now when in the spin cycle the machine starts to excessively vibrate. Could something be out of alignment and if so can I fix this problem??? thanks
  • 639 Answers
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Have someone help you to level the machine using a spirit level on top of the washer and adjust the legs up or down accordingly!
Other wise you need factory service!
If your not sure what you are doing stop... and call service!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
SOURCE:
Admiral Washer
Yes motor can move left to right with your hands.
Apr 12, 2014 | Admiral AW22 Top Load Washer
Admiral washer will agitate but will not spin dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
Admiral washing machine will not start
admiral washer machine will not start and before it died there was a weird noise coming from the machine.
Jun 28, 2010 | Admiral AW22 Top Load Washer
Cold water wash and rinse not working.
check the screens on the water inlet valve and or replace the valve
May 19, 2009 | Admiral AW22 Top Load Washer
Don't spin or drain
Motor is not reversing or going into spin for some reason, could be lid switch, programmer or motor, go for lid switch first - short out to test, but do not use without switch.
Apr 05, 2009 | Admiral AW22 Top Load Washer
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
My Admiral washer machine moves and shakes all over the place on the spin cycle what is the problem
It needs to be rebalanced.screw the front legs down first tilt the machine up from the front slighltly to automaticly re adjust the back legs (shouldnt be any screw legs there) then manualy re adjust your front legs. this happen a lot when you wash big loads or blankets and such etc. and is normal glad to help you
Jan 08, 2009 | Admiral AW22 Top Load Washer
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
80 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
