Question about Lenovo 3000 C200 8922 - Celeron M 420 1.6 GHz - 15in. TFT (S6420812) PC Desktop
Internal hdd none in bios set up - Lenovo 3000 C200 8922 - Celeron M 420 1.6 GHz - 15in. TFT (S6420812) PC Desktop
    Sniper:
  • 66 Answers
Restore bois setting from bios setup menu to Default Settings and then save and exit bios setting
and then bootup.... good luck
Posted on Apr 09, 2011
  • Lenovo Master
  • 32,281 Answers
If the BIOS cannot detect the hard disk, this usually indicates that the hard disk has failed.
To get the Lenovo operating again, replace the hard disk and install Windows in the new hard disk plus
the Lenovo's device drivers and your programs.
USB DVD DRIVE
The pecking order for boot is controlled as you have said by the bios. I have found that not all USB connections are the same and have had to try the different USB connections to get one to boot.
Make sure that the DVD is a system boot disc and is in the drive when you power up.
If the HDD is still on the boot BIOS list I would try removing it from the list. The drive should still be available but the BIOS will not see it as a boot choice.
You may want to swap the SATA connections on the HDD drive making the SYS HDD no longer the default boot.
It is possible that the drivers for the DVD drive you are trying to boot from are not loaded and the drive is not accessible. Look at the bios using setup after turn on to see if the DVD drive is registered. It may be it gets its driver later during the windows boot.
You may have to use more of a generic DVD drive.or internal drive.
Jan 06, 2016 | Computers & Internet
My mitac m32-sp3068 desktop computer,says bios cannot find hard drive or discs
Possible hdd failure. Reset the system and check the BIOS settings for the hdd. Make sure the settings are correct.
The system will not lose just a portion of the BIOS, all or none.
Sep 30, 2014 | Computers & Internet
No HDD Detected
try it once..... Go to the bios ... try to change the boot priority... to hdd from cd-rom Drive....
Steps:- Go to bios settings(search in google to know the exact key if you are not aware of that... search by model no..) --> Boot --> look at the bottom of the page and follow the instructions to make HDD default...
Jul 06, 2013 | Gateway Solo Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Inspiron 531 wont boot up. just get dell screen then says Sata 0 Sata 1 Tsst corp DVD sata 2 None sata 3 None
If yo are sure that you have a working operating system on your hard disk , and this error started after you (probably) defaulted the Bios settings or something else did ....Than I think the lack of sata raid driver makes the reading of your hard disk impossible ..To fix this ..either try to reinstall the operation system and during it ..choose to add a 3rd party driver (look for raid driver on your motherboard cd ..or on the manufacturer's support site ) ..or ..just get into Bios again ..look for the HDD in the advanced options ..and select the hdd 0 ..and eliminate the achi feature ..and replace it with sata as ide ..or compatible ..and save settings with F10 and restart ..It will make the hdd visible ..and support installation if it has non ...or just boot up ..but will work as IDE and not raid ..
Aug 23, 2011 | Dell Inspiron 531s Desktop Computer
I have a Seagate Barracuda HDD not detected bios: Family: 7200.12 Model: ST3160318AS Size: 160Gbytes Firmware: CC38
Check that the small jumper is set correctly: MA(ster) or SL(ave) or C(able) S(elect).
Check that the disk-drive is getting electrical power (vibrating? getting warm?)
Check that the data-cable between the disk-drive and the motherboard is connected at both ends.
Check that the BIOS settings for disk-drives are set to 'AUTO' (not 'NONE').
Mar 18, 2011 | Computers & Internet
New HDD not recognising on laptop
what size capacity is the new hard drive - and what is the bios on your laptop able to recognise ?
is it an upto date laptop ?
some old bios's unable to see newer larger drives....
try updating the bios of your laptop
or use a hdd prep programme
Oct 11, 2009 | Computers & Internet
Dell GX270 does not recognise HDD after CMOS battery failure
It Seems to me IDE HDD In your BIOS should be set to on.
Mar 11, 2009 | Dell OptiPlex GX270 PC Desktop
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Lenovo 3000 C200 8922 - Celeron M 420 1.6 GHz - 15in. TFT (S6420812) PC Desktop Logo
630 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
