Question about Cycling
Hi, the crank slips around as you are peddling, how can I fix it? Thanks
    Brigadier General:
  • 8,546 Answers
Evaluate what is really happening. The chain has to engage in the teeth both front and rear or it will seem to slip.
If your drive train is original, high-mileage and/or under-maintained you probably have worn gears and a 'stretched' chain.
http://sheldonbrown.com/chains.html
http://bicycletutor.com/chain-wear/
Total replacement is the only way to resolve worn
Incorrect rear derailleur adjustment will allow unintentional shifting between adjacent gears which sometimes feels like skipping.
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Posted on Apr 09, 2011
How do you remove / service the bearing on the bottom bracket? I have tried to open the assembly but have been unable to separate the crank. There is a defininte creak when under load and "sometimes"
On a bike???! On a bike to service the bearings
at the crank (peddles) remove chain
rrmove peddles then there will be a lock
nut at base of peddle crank remove it
then slide the whole crank out of the
opposite side an there you go you will
have you bearings in plan view if bearings
are busted replace if they are good
clean an repack with grease an reassemble
Jun 13, 2014 | Merida Mission 3000-D
How to fix mercedes 1998 ML320 ets light
Hey,ETS stands for Electronic Control System, a diagnostic check is needed to verify which sensor, wiring or module is fault. The ETS is part of your ABS system, they share speed sensors etc. The ETS light will come on when its activated (car slipping while foot on the gas peddle) and the ABS light will turn on when its activated (car slipping while foot on the brake peddle).
hope this helps
May 08, 2014 | Vehicle Parts & Accessories
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
I own a 1995 Audi 90cs. My clutch peddle started being dead tell half way down then got preshure. Now there is no preshure and the peddle sticks to the floor. There was no slipping in the clutch so I
You need to replace the clutch slave.....Ii recently did mine, after the installation it was stuck too.......the way I fix it was I had a friend pumping the clutch by hand while I bleed it under the car, it took about 15-20 minutes before it got hard again.
Aug 01, 2012 | 1995 Audi 90
When driving at around 45mph and i realese the gas peddle you get a hissing sound from the differential
Either you need to change the grease in the rear and add a bottle of limited slip differential additive or the pinion bearing may be bad. Both are familiar problems on this model.
Aug 18, 2010 | 2000 Jeep Grand Cherokee
Left peddel is stripped will not stay on
If it is the peddle that is threaded and not the crank then all you need to do is replace the peddle. Take the peddle off and look at the thread both on the peddle and inside the crank. Any bike shop can look at this for you and can order you in a set of new peddles or, if the crank is to blame you can order these easy enough online.
Jun 09, 2010 | Huffy Brazen 20 Boys' Freestyle BMX...
When peddling the pedels slip
Check your chain and see if you have a link that is stiff. If so, this can cause the chain to slip over the gears. You can try soaking it in oil or WD40 and once its free put some chain lube on it. Hopefull this will help. Good luck!
Mar 07, 2010 | Mongoose 20-Inch Gravity Games BMX...
When I push on the peddle of my sewing machine nothing moves.
The rotor motor must have gone bad.
Please take it to a service center around you for proper repairs as it will not cost much.
Good luck.
Dec 15, 2009 | White Sewing 1999 Mechanical Sewing...
How do i fix a wonky pedal?
Check and see if where it is screwed in is still tight. If it is then the steel shank that the peddle turns on is bent and you will have to replace the hole peddle.
How to take the peddle off is use a wrench that fits the nut that is between the peddle and the crank arm and turn it out. This will be in there real tight and my take some muscle to get it loose.
Oct 04, 2009 | Cycling
Cycling Logo
115 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
