LG Invertor Gold system Condenser Unit : FMU 3060 W4M, Auto Power Off, and Power LED starts to Blink 11 times.
3 Suggested Answers
  • 29 Answers
SOURCE: Outside unit runs continuously, even when system is off.
On A/C units, there is a low voltage line that leads to a contactor, which engages to close the high voltage circuit to the condensor unit. Over time, the accual contacts in the contactor can weld themselves together. Try shutting off your furnace breaker but leaving on the one for the outside condensor unit. If it still runs, your contactor probably needs replaced. Contact a licensed electrician or HVAC contractor and tell them you think your contactor is in need of replacement. Is a fairly simple and quick replace, but the contactor itself is not cheap.
Posted on Oct 10, 2009
  • 715 Answers
SOURCE: Ouside unit runs continuously, even if system is off
the contactor is stuck you might try killing the breaker to the condensing unit if it stops then it is the contactor
Lg intello air ac led blinking many times but compressor and indoor unit are running
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset West Palm Beach Air Conditioning
Jun 01, 2016 | LG Heating & Cooling
Have a LG 55ls5700 tv that doesn't turn on but the red standby comes on and when i press the power button it starts to blink
Does the screen quickly blink on and then off? Does the standby light slowly blink twice and then go out?If these are the symptoms then it is probably a bad led backlight strip.This was the fault with my lg 47ln540v led lcd tv.I have written this up in a previous post more comprehensively.Hope this helps..
Mar 19, 2015 | LG 55LS5700 - 55 LED LCD Smart HDTV,...
How to repair power supply
It's probably the 'invertor', not the backlight or powersupply. That is assuming that the power-led does turn on ?
Jun 29, 2014 | Dell Entry E2311h 23 Led Lcd Monitor -...
How to fix LG error code ch 23
there is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
Nov 21, 2013 | LG LSC091PMA Split System Air Conditioner
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Westpoint air conditioner malfunctioning When the unit is turned on after a few minutes the auto light starts to blink and the compressor does not come on.
Either the condenser fan is not working or not blowing properly, so the unit builds up heat in the condenser which causes high pressure and the system goes off starts to blink
May 11, 2011 | Refrigerators
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
BLINKING POWER LIGHT
HOW MANY TIMES DOE IT BLINK
BLINK: SHORT-LONG-BOTH-MIX
EXAMPLE: 1 LONG BLINK AND 1 FAST BLINK IS A VEDIO AND MY ALSO BE A BOIS ERROR TOO.
THE LONG LIGHT MAY MEAN A POWER ISSUES, FAULTY WIRE, FUALITY POWER SUPPLY, INTERMITTING POWER SIGNAL TO THE COMPUTER SYSTEM
3-1-2- HARD DRIVE DMA ERROR
ROD
Feb 02, 2009 | HP Pavilion a705w PC Desktop
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
