Question about Alpine MRV-F407 Car Audio Amplifier
MRV-F407 - Alpine MRV-F407 Car Audio Amplifier
3 Suggested Answers
trintek
  • 111 Answers
SOURCE: need a part for my alpine mrv-f407 amp
as far as i know, nobody stocks or sells replacement cases for this amplifier, your best bet would be to search for a good dead one on ebay or somewhere similar... failing that, you can take the case apart and use an aluminum or metal paint to repaint it after sanding it. the reason for using a metal paint is that most regular paints will have an unwanted insulating effect and not allow the case to perform its intended purpose, giant heatsink. you can also try to use metal polishes or an extremely fine grit sand paper (1000-2000 grit) to remove any scuffs and polish it at the same time, but this will remove any factory paint. i believe krylon or one of the other brands makes a metal tint paint that is translucent, i have used it to color match amps to cars and it seems to work well. it can be found at just about any napa or other automotive shop and i believe it is intended for wheels, bumpers, etc.
hope this helps,
trin
Posted on Nov 16, 2007
  • 111 Answers
SOURCE: I need to know what the wattage the alpine
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Posted on Apr 30, 2010
Require a users manual for my pioneer file type compact disc player model PD-F407
Direct Download Link for manual :)
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/282719879PD-F407%20PRE1297A.pdf
Jun 14, 2011 | Pioneer Car Audio & Video
The protection light comes on when I turn it on.
Check your ground wire. It should be solidly connected to the vehicle chassis in a a paint-free location. Also make sure the speaker leads aren't touching each other at the input on the amp. Then make sure your live power wire has a good connection to the battery and the amp. Finally, check the speaker leads along their entire length, and make sure they are not touching the vehicle chassis.
Mar 09, 2011 | Alpine MRV-F407 Car Audio Amplifier
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=MRV-F407
THE ABOVE LINK WILL DOWNLOAD A MANUAL FOR THE SIMILAR MRV-F407 AMPLIFIER. IF YOU WANT TO PURCHASE THE EXACT MANUAL, YOU CAN OBTAIN IT FROM PACIFIC COAST PARTS AT 800-421-5080 PART NUMBER=68P50958W56. IT IS AROUND $5.00 PLUS SHIPPING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 24, 2009 | Alpine MRV-F540 Car Audio Amplifier
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
Need a part for my alpine mrv-f407 amp
hope this helps,
trin
Nov 08, 2007 | Alpine MRV-F407 Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
