Question about E-Machines M2350 Notebook
Acciring network address but wont conect cant get ip address
  • 942 Answers
Try to disable the LAN by clicking Start > Control Panel and then click Network Connections . Then right click Local Area Network connection then click disable. Restart the pc and do the same thing except you will enable the Local Area Network. Check if you will have internet connection..
Posted on Apr 09, 2011
Router wont conect to network
Make sure your router is using the same ip subnet as the network.
Your router may be preset with a certain subnet and be set to hand out IP addresses via DHCP. If you are on a business network - you want the network's DHCP to hand out an address to the router... or you can configure a static IP range on the router that matches the network.
Dec 07, 2010 | Belkin Computers & Internet
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Describe your my sony vaio cant find an ip address Problem
my computer wont conect to the internet anymore, and i think it might be my ip address?????
Feb 28, 2010 | Sony VAIO PCG-K35 Notebook
Conect to network
you have to setup in printer menu option
network settings
-> TCP/IP settings
-> IP address
-> subnet mask
-> Gateway address
and ping the ip of pirnter form pc and install the driver .
Jan 28, 2010 | Office Equipment & Supplies
Installing new wireless g business ethernet bridge my problem is i cant connect to ip address for set up 198.168.1.1 does not connect neither does192.168.1.226 what now. i have internet conection on 2...
You need to manully assign your computer an address in the 12.168.1.x range with a subnet mask of 255.255.255.0 rather than whatever is currently being used(most likely assigned by DHCP),
Once you do this and connect to the device, it is best to normally give it an address in your norml ip range, reset your computer back to normal, and then re-connect using the newly assigned address to verify it has been done correctly.
Depending on the model, you may also have the option of making the initial connection with a serial cable and then make any desired changes including device IP address by this method.
Oct 03, 2009 | Computers & Internet
Wifi signal canot conect because of DNS problem
see pal.for this you do require ip address settings by that i mean ip address,subnet mask and default gateway.if you do have these settings then the dns address can be used for static ip address primary = 4.2.2.2 & secondary = 4.2.2.3
take care
Jul 10, 2009 | Computers & Internet
Cant play online games
Here are few things that you can try:
1. update the firmware on the router/modem
2. Open ports on the router/modem for P2P
Jun 10, 2009 | NetGear DG834G Router
Wont conect to internet
hi. sir.
go to the internet option>
connection>
setup> choose which type u need to do>
see whether the modem is enabled first. thank u. sir
Sep 03, 2008 | Dell Inspiron 1100 Notebook
My wii cant connect to my wireless conection
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the Wii but add 1 to the last number for the IP Address as this has to be unique on your network
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
Westell 327
make sure both computers are using the automatic ip configuration. check this by clicking START, CONTROL PANEL, NETWORK CONNECTIONS, then right click on your connection and click PROPERTIES, in the white box with the 4 options highlight TCP/IP and click PROPERTIES. The "obtain ip address automatically" circle should be ticked, and also under the ALTERNATE CONFIGURATION the circle "automatic private ip address" should be ticked
Jan 12, 2008 | Westell Wirespeed VersaLink...
E-Machines M2350 Notebook Logo
106 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
