Question about Symbol MC9063-K (MC9063KHFHBEEA7WW) Barcode Scanner
I am stuck at the align screen and won't move forward
  • ericmendez8 Apr 09, 2011
    The reply did not help at all and was way off the mark
  • 438 Answers
Eric,
The firmware of the device is corrupted. Please re-install it or have it re-installed from the service center.
Posted on Apr 10, 2011
    Guru:
  • 1,833 Answers
Open your Symbol MC9063-K Barcode Scanner, and check whether any paper or a little part of the paper stuck inside the scanner, and also check the rollers. If your problem still exists then you should consult with a tech man at http://www.barcodediscount.com/catalog/symbol/part-mc9063-kkghbeea4ww.htm,
http://support.symbol.com/support/mysupport/support.do?id=m2.
Posted on Apr 09, 2011
Transmission won't engage
when you had the wheel off did you loose one of the square keys that go between the axle and the wheel hub
May 06, 2012 | Garden
Poulan HD145H42 won't go forward very fast
You seem to have a gearcase issue...like it's stuck in 1st. Have it checked by an equipment repair center.
May 05, 2012 | Poulan Garden
My truck is stuck in drive and I cannot move it to any other gear. My key is stuck in it. I push on the brakes to try and get it to move and the brakes will not go down. Help!!
you will have to move brake pedal lock switch by hand while you wiggle key switch forward and backward to get them to align back up with shifter safety its a little tricky but will enable you to get it in park and remove key
Mar 26, 2012 | 2002 Chevrolet Avalanche
Nikkor 55-200 stuck
You could take it apart, but would you be able to put it back together? Do you have a lens collimator and other gear needed to ensure proper alignment? If you don't have the proper tools, leave the job to a trained professional (or replace the lens).
Nov 18, 2011 | Cameras
My htc touch pro2 stuck on align screen
Where ever the cursur is press and hold with the stylus until it moves (don't just tap) to the next spot. Do this 3-4 times and it will eventually align the screen for you.
Nov 29, 2010 | Cell Phones
Stuck on align screen...
You must tap the exact center of the '+' symbol with the stylus pen 5 times: at the middle and at each corner of the screen (it will move itself as you go tapping). If you miss one of them, even slightly, the process will be restarted.
Hope you are able to align your screen and move on.
Cheers! Carlos
Apr 16, 2010 | T-Mobile Wing Smartphone
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Symbol MC9063-K (MC9063KHFHBEEA7WW) Barcode Scanner Logo
106 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
