Question about Hotpoint WMA66 Front Load Washer
After the machine has finished its wash there is no water in the drum the following morning the drum is half full with water with no warning of this so if you open the door water spiles out.
If the water is clean, there is a problem with the water inlet valve, there may be a small piece of grit or similar preventing the valve from closing completely, or the rubber washer in the valve has either got hard or split and the valve is not sealing completely. There may be 2 valves, or a double and single valve in the machine, and to find out which one is leaking, the simplest solution is to ensure the soap dispenser is empty and dry, and put a piece of paper towel in each section, one of the pieces will be wet the next day, and it's the hose that is over that section that the water is coming from, follow that hose back and you should know which valve is not correctly sealing.
Posted on Jul 20, 2011
When the washing mashine is finished, after two days water appear in the drum.Slowly but after one week probably would be full drum.What is the problem?
The water valve needs to be cleaned out or replaced. The water valve is the part on the washer that the hot and cold hoses hook to.Hope this helped.
May 29, 2011 | Washing Machines
About 1-2 times a month, my front loading washer fills up with water (sometimes a little and sometimes about half full) without being turned on ... any ideas?
Leaking water inlet valve. Turn hot water valve off one night n see wether any water in drum in morning. Then try turning cold valve off at hose as well to see which one is letting the water in. Either way its only a $5 dollar bit thats passing water
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
I haven't used my washing machine since sunday and keep it unpluged at the wall when i'm not using it, this morning my drum was a third full of water. what could be wrong with it? ZWF 1221W
If you had it unplugged then probably the water inlet valves are not closing completely therefore allowing water to come in the tub.Just a guess, not really sure
Aug 26, 2009 | Washing Machines
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WMA66 Front Load Washer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
