Question about Cell Phones
Initially when the bluescreen started it was on and off. Occasionally I had to switch of the phone and back on and it worked but it finally went permanently blue. No tricks would make it worked this time. I can still receive calls though nothing is displayed. I have been using this phone(nokia 6085) for 2years. Any assistance would be very much appreciated. Thanks. Nathan Aklasu
  • Nathan Aklasu Apr 10, 2011
    Thank you very much for the information. I'll look around for the replacement flex cable to buy and replace it as soon as possible. Thank you so much.
  • 133 Answers
Go to Nokia Service Center, there's a problem with the FLEX of your cellphone or simply the ribbon that connects the LCD of your cellphone to it's motherboard.
Please don't forget to rate! Thanks!
Posted on Apr 09, 2011
What would cause dash lights and gauges to not come on occasionally when key is turned to the position just before starting the car?
I would initially suspect a bad ignition switch (not the lock....the actual switch). It could also be a short poor ground, failing component on the instrument cluster board etc. Try go ogling your problem with your specific year make and model to see if this may be a common issue.
Oct 09, 2016 | Cars & Trucks
My hp mini 1000 wont boot up. when i turn it on it goes right to a screen that asks how i want to start up windows ( safe mode, safe mode with networking, safe mode with command prompts, and start windows...
hi blinkgirl556
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
hope this helps
contact me for any updates
janc30
Feb 08, 2011 | HP Mini 1000 Netbook
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a HTC 6800 that started acting funny about a week ago. At first the screen got lines across it when I would open the keyboard, then after a couple of days the srceen just froze when the keyboard was...
I had this same problem, there is a thin line of wires connecting the bottom half and top half of the sliders, after awhile it just plain wears out and will generally crack, without these wire anything on the front of your phone will no longer work. The screen is black but stil lights up a little bit and occasionally the buttons light up but its pretty much toast I'm sorry to say. I upgraded to a HTC Touch Pro 2 and am happier than ever!
Jan 18, 2010 | HTC PPC-6800 Smartphone
APPS ARENT WORKING
Initially do a cold restart of the phone...hold Home and Top until the phone shuts down even if you see the slide to power down..keep holding.
I would start by restoring the phone through iTunes to a previous version where things were working. Finally if all fails you will want to wipe the phone and start clean.
Jan 09, 2010 | Apple iPod touch
Bluescreened a few times and went out? I updated
Try testing the memory modules 1 at a time to check for faults. Bluescreens are commonly caused by bad memory especially with XP.
Dec 08, 2009 | MSI K8N Neo3 Motherboard
Bootloader usb init
hold the end key(power) and it should restart back to normal. If it goes back into bootloader then your phones software could be corrupt or could have a wrong value in somewhere. What provider is this?
Jul 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Dell optiplex GX280 bluescreen hardrive problem
It appears that the boot sector of your hard drive became corrupted. The problem is not hardware related and should be fixable by using the restore CD that came with your unit.
Dec 26, 2008 | Dell OptiPlex GX280 PC Desktop
Nokia 6300 -Wont switch on , only has blue lights
your cp having a defective lcd now. it need to be replace and send it to repair center,
Nov 05, 2008 | Nokia 6300 Cellular Phone
Brand new had it for about 2 weeks.
After the bluescreen appears press: middle button > 1x down > select > 5x down > select > 2x up > select > enter pin (6 zeros if you don't know it) > select > top left key
Follow the exact sequence and it will factory reset your phone. You may have to try this multiple times. Caution:This will delete all the contacts, msgs etc on your phone. So make sure you connect it to a comp and back up your data first!
Good Luck!
Sep 18, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
75 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
