Question about Canon imageRUNNER C6800 Copier
When I start a machine there's an error code coming No. E000078-0001 and the machine tells me to shut down. Pse help because it does not work now.
    Problem Solver:
  • 13 Answers
Try cleaning or replacing photo-interrupter ps23, part #FK2-0149. It is located in the ITB positioning assy. which engages and disengages the cleaning blade for the transfer belt. This unit is located behind the gray cover that is next to your toner door. There are a couple of connectors and some black screws that atach it to the front plate of the machine.When I start a machine - rsdurnin.gif
Posted on Apr 12, 2011
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Just Shuts Off
please call a local engineer as we don't know what type of machine your telling us about eric
Dec 28, 2017 | LG WM1814CW Front Load Washer
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Toshiba aw-1190s error code E7-4
MY WASHING MACHINE APPEARS ERROR 2 AND 3.PSE CONTACT 019-2450009 0R EMAILS EZALYIMTIYAZ@YAHOO.COM. ANY SUGGESTION PSE?
Nov 17, 2012 | Office Equipment & Supplies
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
The copier stopped working and Error code E000003-0000 came up. I've shut the machine down and restarted, but error code still comes up.
switch on the machine, press *(additional function) 2and8 together and again *, on screen select copier>function>clear>error>ok. switch off the machine and restart.still problem appears then check fuser unit.
Jan 26, 2011 | Canon imageRUNNER 2200
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
Mar 26, 2010 | Mitsubishi WD-57732 Projection Television
Xerox DocuColor problem
The only thing I can tell you to do is turn off the machine. On the back of the finisher, unplug the finisher from the processor and power up the machine, it will reconfigure, plug and play like, and send the pages to the center tray.
Once you do that. Go into machine status and into faults. Print out a fault page and tell me the finisher/stapler code coming up so I can let you know exactly whats going on.
I hate that software puts a machine down for functions you do not 100 percent need.
Mar 18, 2008 | Xerox DocuColor 12 Color Copier
Canon imageRUNNER C6800 Copier Logo
90 people viewed this question
old marine
old marine
