Question about Nokia E63 Cell Phone
E63 when i inside battary phone will auto start then charging phone automaticly without charger.plese tell me
SOURCE: nokia 6030 charging automatically without charger
some problem in soft wear please flashing the mobile
Posted on Mar 19, 2008
SOURCE: N73 can't charge battary and overheats
REFORMAT YOUR CP
Posted on Nov 13, 2008
  • 31 Answers
SOURCE: No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Posted on Aug 19, 2009
windowvistab
  • 139 Answers
SOURCE: My Nokia E63 is not
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Posted on Jul 05, 2011
raingamj
  • 2148 Answers
SOURCE: why nokia E63 phone automatic restart? plz help me
If the battery is OK then your problem comes from the damage of operating system (Firmware).So, to solve this the only thing you have to do is to flash the phone.You can contact mobile repairing shop or Click here1 if you want to do it by yourself.And for your flash file follow this All nokia bb5 flash file.Good luck
Posted on Apr 12, 2012
I'm nokia E63 user. Battary of this phone ( BP-4L) does not give back up for a day after full charging. Today when i got up in morning i touched my phone and found it overheated. I brought this phone in...
you should replace your battery
or
take the battery out and leave it out for an hour atleast, give your phone and battery little rest then use again.
remember never ever over recharge your battery. two hours are more than enough. and always swtich your phone off when you are charging it.
Nov 10, 2010 | Nokia BP-4L Battery
Nokia e63 notcharging
use a known good battery and try to charge
if still doesnt work try a known good charger or use your charger to a diff nokia device and see if it will charge
if ever a known good battery and charger was use and still it wont charge, your device needs to be service because the IC might be busted and needs to be fixed or replaced.
hope this help
Sep 08, 2010 | Nokia E63 Cell Phone
E 63 not charging folt
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 24, 2010 | Nokia E63 Cell Phone
NO MENU SHOWN
The only way to reset your phone is by pressing the center button key (in the middle of the navigation keys) while turning the phone on.
Dec 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Charge battary without charger
Unfortunately this camera battery requires that the charger that came with the camera be used for charging purposes. It is not possible to connect the camera to the USB port of your computer and have it charge. The camera was not designed this way.
May 06, 2009 | Olympus Stylus 790SW Digital Camera
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
Nokia 6030 charging automatically without charger
Mar 18, 2008 | Nokia 6030 Cellular Phone
Nokia E63 Cell Phone Logo
237 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
