Kenmore front loading washing machine
I have a one year old kenmore. daughters boyfriend was doing laundry, I think he may have opened the door improperly. now flashing f-01, sears says two weeks to get a repairman here [!]
your posting "new control bd" - does that mean it has to have a new circuit board put into it, could there be any other way to fix it? is there a reset? thanks,
    Genius:
  • 1,028 Answers
Best advise i can give is hope your warranty is still in effect.. although there is slim chance of a loose connection on control if you want to double ck remove screws on rear edge of top and remove top by sliding back and off control bd may on right front corner or on rear rail..seriously doubt daughter's boyfriend caused problem seen f01 on month old machines
Posted on Aug 07, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
We have a Kenmore Elite front loader and yesterday while washing a load of laundry, the lights flickered and then the machine turned off. I checked all the breakers, unplugged and replugged and nothing...
There is a pull tab at the bottom of the door latch assembly that can be used as a manual release for the door by pulling it down.
Lean the washer backwards and unscrew the 3 screws under the bottom edge on the front of the washer to remove the lower panel under the door. Once the panel is removed, reach the tab with your hand up inside the washer behind the front casing on the right side and pull it down. The door will open.
If there is an error prior to the jamming of the door, the door latch assembly must be replaced. Feel free to let me know if that is the case.
Dec 01, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t washing machine isn't draining. My daughter put in a load of old material, and some of it just fell apart when it got wet. We cleaned out the junk trap down by the pump, and that...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Kenmore Elite HE5t Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
