Question about Miele Built In Microwave M82601 900 Watts Microwave Oven
I have a Miele M 8201-1 microwave oven which is three years old with a two year guarantee, it has worked very well until now. The turntable is going round and the light comes on, the sound from the oven seems the same but the food is not heating. It worked fine yesterday, this morning it got food lukewarm, but now it is not heating at all. Any idea what the fault could be?
  • davebarritt Apr 09, 2011
    Thanks for your help, ginko.
  • Miele Master
  • 19,396 Answers
Hi.
If the microwave is working but not heating, then the problem is often the magnetron (the wave emitter), but there are more parts that can commonly give the same problem not powering the magnetron.
Before replacing the magnetron there is need to test the high voltage capacitor,the rectifier diode and the wiring. Such parts are easier to test than the magnetron. If all this are fine, then the control board must also be checked .If turntable is not running the door switch must be tested as well.
The diode and capacitors can be tested using a tool with diode tester and cap meter. The capacitor must be allowed discharge before testing, or you risk to get electrocuted. Even if power is off a big electrolytic capacitor like the one on the MW can release a big discharge.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the general diagram here: Counter top.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed after the oven is serviced or repaired.
Call the Miele number listed on your owner manual to get a quote from a qualified repairer.
Regards.
Ginko.
Posted on Apr 09, 2011
  • Ginko
    Ginko Apr 09, 2011
    Hi Dave.
    You are welcome.
    All the best.
    Ginko
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
May 14, 2014 | Miele M625EG Convection Microwave Oven
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Heating element does not work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;,;;,;
Jul 10, 2010 | Maytag MMV4205 Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
Please reply back with your brand and model number so we can help you.
Jan 07, 2009 | Maytag MMV5156AAS Microwave Oven
Fan runs and turntable turns when door is opened
SRUte- This sounds as if you have a collapsed door switch, this would cause this problem,I would not recommend using it until repaired. But as far as recommending a good brand,each to his own everyone is different.I have done repairs for years,and I Love Panasonic products,they seem to have minimal problems.I hope this helps you out. cooltek Mar,3/08
Mar 04, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Miele Built In Microwave M82601 900 Watts Microwave Oven Logo
641 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Ruth summersides
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
