Some of the wires come undone and i need to know how the wireing go
  • 413 Answers
Take a pic and someone can probably tell you
Posted on Apr 09, 2011
I have an Edwards C210-W Economy Door Chime for my livingroom door. Wires came undone while painting and I don't know which wire goes where. Yellow wire coming out of the wall is from the transformer
They are connected to the chime terminal board with 3 connections!
1) wire from the transformer.
2) wire from 1st push button.
3) wire from 2nd push button.
Dec 29, 2015 | Cars & Trucks
The blue wire came undone, does anyone know where it goes?
No one knows what that question is about
Nov 14, 2014 | Cars & Trucks
We hooked our panasonic 5 cd changer stereo to our computer and the wires came undone....which wires do we wire back together?
There is no way for us to just 'know' your sound card features or the make/model of your "5 CD changer stereo".
Analog? Digital? IN to the PC or OUT from it? Or both? Manuals help.
Search engines provide all kinds of immeduate advice for these questions.
"connect audio to a pc"
Jun 16, 2011 | Panasonic Audio Players & Recorders
Hello i need help to replace my starter but dont know where to start
make sure your cable wires are undone from your battery very important them undo the the ground from starter and 4 blots..
Jan 23, 2011 | Chrysler Town & Country Cars & Trucks
The primary radiator cooling fan on my 1993 HONDA Accord won't run. The fuses and relay are good and I checked the fan by running power directly to the fan plug. It ran just fine so the motor is fine. ...
You need to check the the power going to the fan. Is the wiring going to the fan broken? Is there a bad ground wire? Did the power wire come undone from the harness? Check the wiring and let me know. I hope this helps
Dec 31, 2010 | 1993 Honda Accord
The coolant temperature sensor wires came undone and I need to know how to connect them back.
Undone how?
Backed out of terminals?
Release the terminals from connector and remake,then solder
Nov 08, 2010 | 1992 Toyota Corolla
NIKKO CAR CIRCUIT DIAGRAM C1059CA DATASHEET
my Grandson got a modern mustang radio controlled car last Christmas. One to many slamming it into things, one of the battery wires came undone. The brown wire, if that helps. I need to know where it reconnects to?
Thanks
Dec 16, 2009 | Nikko Toys
Wire that earths itself using a female connector has come undone from the other end but dont know where from . its a black wire with just loose wires
The grounding circuit is as follows... from coil/ module to kill switch if switch is mounted in plastic then a second wire will leave switch to a ground on motor. So it either came off module or the ground on the motor. Unit should run normally but would not be able to shut it off with wires disconnected.
Nov 22, 2009 | Ryobi Garden
My climate control is not working , what do you suspect.
hi there climate control not working on a leganza cdx if the panel does not lght up it is an earth problem , remove the glove box and behind the radio in the loom you will find a plastic conector with a cap in the end of it this is an electrical splice pack that is used to connect many wires into one wire you will find one of the earth wires has got hot and burnt out you need to bypass this wire and connect it directly to the main earth in the splice pack
Nov 06, 2009 | 2000 Daewoo Leganza
A wire has come undone somewhere that hooks up to the fuel pump and I can't find where it has come undone from ?
if it is a black wire it is a ground.they are usually just attached to the frame with a small screw.
Jul 30, 2009 | 1994 Chevrolet S-10 Blazer
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
