Question about Dryers
Replacing Drive Belt on a Hotpoint TL22 Drier
Could someone describe or show with a diagram how to go about changing a drive belt on a Hotpoint TL22 drier
  • Diver2 Aug 10, 2008
    Thank you Guest for wasting everyones time. Cheers!
Great site now i know exactly what i knew previosly... NOTHING
Posted on Aug 08, 2008
SOURCE:
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How to replace a serpentine belt on a 2010 Kia Forte?
kia forte drive belt - Kia Forte Forum : Sedan / Koup / Forte5 Forums
www.forteforums.com/.../kia-forte-2-0l.../40769-kia-forte-drive-belt.htm...
Dec 19, 2013 - 8 posts - ‎3 authors
im trying to replace the drive belt on a 2010 kia forte ex 2.0l and was wondering if someone could get me a diagram of the belt routing as well ... Squeal in serpentine belt area even after replacing ...
Nov 8, 2014
Serpentine drive belt -very frustrating-
Jun 17, 2014
Recommended mileage timing chain change SX
Mar 23, 2014
Serpentine belt removal on a 2.4L. Anyone?
Aug 11, 2013
More results from www.forteforums.com
images for serpentine belt diagram on a 2010 Kia Forte
Jul 03, 2014 | 2010 Kia Forte
Replacing the drive belt on a hotpoint tdc30p and need a diagram of how the belt goes round the drive and pulley system
wrap the belt around the drum first then the slack at the bottom wraps around the motor shaft. Then it has to go either left or right side of the tensioner wheel, but the flat side must touch the tensioner wheel(not the ribbed side of the belt). You know you got it right when when there is tension on the belt when it is correctly installed. I dont have diagram so this is the most simplistic way of describing how to install it.
Feb 26, 2014 | Dryers
Hotpoint ctd80 tumble drier drum not moving but still heating up
yes it will b the drive belt and its a easy repair.
Jan 17, 2012 | Dryers
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Please rate my solution.
Thankyou.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Replacing the tension belts on the reFord windstar 1998.
FOR COMPLETE Diagram Of this Procedure and Belt Routing Email [email protected]@aol.com and I will Send DETAILED PICTURE and Instructions
NOTE:
  • Minor cracks in the V-grooved portion of the serpentine drive belt are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
  • When installing drive belts on pulley, make sure that all V-grooves make proper contact with accessory pulleys.
Conditions requiring drive belt replacement are excessive wear, rib chunkout, severe glazing, frayed cords, etc. Replace any drive belt that exhibits any of these conditions.
REMOVAL
  1. Using a 15 mm socket or wrench attached on drive belt tensioner pulley bolt. Rotate drive belt tensioner clockwise to remove drive belt from pulleys. WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP.
INSTALLATION
  1. Install drive belt over all accessory pulleys (except drive belt tensioner).Rotate drive belt tensioner as described under Removal to install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys
Feb 10, 2009 | 1998 Ford Windstar
Belt change on TL22
You might want to check to make sure that you bought the correct replacement belt. A new belt SHOULD fit correctly if the replacement belt is the right one? Did you buy an original belt or a generic one? I have ran into problems by trying to substitute for the original. If I were you, I'd double check the belt #. It sounds to me like the belt might actually be the wrong one & be a little shorter than the original. Let me know if that works for you? It should. Good luck and have a good day!
Jan 13, 2009 | Hoover HDC7FM Dryer
Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
LFitting drive belt to Hotpoint VTD00P tumble drier
boil the kettle...drop the belt in for a few minutes... hold the belt and put under ur feet.. stretch itttttttttttt!!!! a few times.. it will stretch believe it or not to approx another 1 to 2 inches.. then fit the belt.. it WILL be tight..and SHOULD be... little elbow grease to take it that last few centimetres and BINGO!!
Mar 25, 2008 | Dryers
Dryers Logo
258 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
