Question about Crosley CDE6000 Electric Dryer
If the Timer on a Crosley CDE8000 Dryer was not properly wired, what could be the possible effects?
4 Suggested Answers
  • 52 Answers
SOURCE: My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Posted on Sep 18, 2009
heatman101
  • 43501 Answers
SOURCE: my crosley dryer will not start when pushed, the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 05, 2010
heatman101
  • 43501 Answers
SOURCE: MY CROSLEY CDE8000 DRY SOUNDS
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Feb 01, 2011
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Aug 17, 2011 | Crosley Dryers
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
MY CROSLEY CDE8000 DRY SOUNDS LIKE IT HAS A BALL ROLLING AROUND IN IT
heatman101
Feb 01, 2011 | Crosley Dryers
Will not heat just cold air and once it reaches 32 min left it stays there
Sorry for the troubles sounds like you have a bad timer since its not heat then the timer wont advance past a certain point. I would recommend you calling a qualified service technician come look at it and to replace the bad timer or you can do this yourself. You will need the model number off the dryer which will be on the back of the unit on the dash or inside the door opening take that number to your local appliance parts house so they can get you the proper timer. Now for installing it make sure you unplug the unit and then you will have to remove the back cover panel on the dash once removed slowly remove wire by wire replacing it to where its suppose to go on the new timer if you put a wire in the wrong spot you will fry the new timer once completed remove the old timer it should have 2 screws holding it to the dash and replace it with the new timer and put your cover back on and then plug it back up and set the timer to 60mins on the timed dry and tune it on and see if it Advances and heats. I hope this helps and thank you for using FixYa!
Jan 27, 2011 | Crosley CDE6000 Electric Dryer
My Crosley Dryer, model # CDE7500AZW doesn't heat up. Possible soloutions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Crosley Dryers
Dryer is but does not heat and timer will not move
heatman101
May 28, 2010 | Crosley CDE6000 Electric Dryer
When i push the push knob the dryer will not start...the electric is there i need to know how to repair the push knob
If you are talking about the starting switch "knob", you will not normally repair that, you will replace it.
If you are talking about the timer switch you normally do not repair the timer switch either...replace it.
If you do decide to replace either switch, remove and replace one wire at a time, this will save you problems with the wiring.
Sep 26, 2009 | Crosley CDE6000 Electric Dryer
Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Sep 16, 2008 | Crosley CDG6000 Gas Dryer
Crosley CDE6000 Electric Dryer Logo
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
