Question about Samsung ML 1610 Laser Printer
Print spooler is automatich stop &dont send error
    Scholar:
  • 111 Answers
Uninstal the driver from your computer and then reinstall them to it, loks like a driver problem.
Posted on Apr 10, 2011
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Print spooler not running. Dont know whether its connected but ive just had live help from microsoft for sound problem
Hi!
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Feb 16, 2011 | Lexmark X1190 All-In-One InkJet Printer
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
I sent a print job to the printer and it started to print and just stopped. The ink, paper, & power source lights all began flashing simultaneously. There was no paper jam and the ink cartridges are...
make sure there is no pending print job in print spooler if it is there then clear it before giving the print .for clearing In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Nov 21, 2009 | Epson Stylus 880 InkJet Color Printer
Getting error message 1018 with the print spool for my HP 1018 printer. HP support will not correct the problem since the print spool is a Microsoft problem.
please check the below........
1. goto start....>run...>type sevices.msc...>enter....>goto print spooler...>double click over there....>select automaticaly....>click start....>ok
Restart the Print Spooler service. To do this, follow these steps:
o Click Start, click Run, type net stop spooler in the Open box, and then click OK.
o Click Start, click Run, type net start spooler in the Open box, and then click OK.
if its not working please post your full error massage u are getting .or you can send your details to me at anantakumarjena0@gmail.com
Oct 26, 2009 | HP LaserJet 1018 Printer
Spooler servis dont work
Resolution:
Aug 25, 2008 | HP Office Equipment & Supplies
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Samsung ML 1610 Laser Printer Logo
26 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
