Question about Toshiba Satellite L305-S5907 2.0GHz Pentium Dual-Core T3200 4GB 320GB DVDRW DL WebCam 15.4" Vista Ho... (PSAG0U01900L) PC Notebook
Laptop came with 4G memory, but when I enter the system properties it says that only 2.87 of the 4G are usable.
I have increased RAM from 2 to 4GB and installed Widows 7 64 bit. Computer properties show RAM 4GB 2.75GB usable. 1282MB reserved. How do I make more RAM usable?
It's the shared memory for the Integrated graphics card, your RAM shares memory to the graphics card, and you are using a lot. If you want more memory, enter BIOS and there should be something about shared memory, and put it at 256 MB or so.
See also here:
Windows 7 help and support forum
Installed memory 4GB but only 1 93 GB is usable shows in system properties...
May 31, 2015 | Computers & Internet
DELL Precision WorkStation 390 6GB installed but show 3GB usable
your system uses 3 gb,you havent lost anything you have 3 gb dedicated ram and 3 gb useable ram
Apr 04, 2015 | Dell Computers & Internet
4gb RAM only 2gb usable. Very slow new unit.How do I get the 4gb working.
Please check the system usable memory in BIOS. You can define the share pattern of graphics memory & system memory according to your usage. Also check your operating system; Only 64bit operating systems will support more than 3GB
Mar 07, 2015 | Medion Computers & Internet
Installed 2 g memory in pavillion but only detect 512 why?
Check the advanced boot options.
1. Go to Start, in the search bar type msconfig and press enter.
2. System Configuration window will open on the screen.
3. Click on tab named "boot".
4. Click on "Advanced Options" and uncheck the box for "Maximum Memory".
After booting to Windows, check the memory displayed in system properties. 32bit versions of Windows will not recognize more than 4GB of memory. Systems with integrated video subsystems will reserve memory for video, futher reducing the available amount shown in the OS.
Mar 14, 2013 | Computers & Internet
How to use all my ram on Asus Eee PC Netbook
You are using all of it already. You computer has allocated part of it for your integrated graphics card. That is why it appears to have less.
Aug 18, 2012 | Computers & Internet
I want to reinstal all the operating system, how can i do?
1- put all of the files of OS in a flash Memory.
2- connect flash Memory to your Notebook.
3- wait till the notebook says "press any key"
4- enter the installation.
(installation is so simple and i think there is no need of clarification)
but if you want more solution only ask for more.
Jan 15, 2011 | ASUS Eee 4G Notebook
Hp xw9300 has 4gb of memory installed however the system properties only shows 2 gb of memory. the bios shows 4gb of memory
This article alnog with the possibility that your graphics card is using maybe a gig of memory may explain why you don't see the 4G memory in system properties. Of course it would be useful to indicate what operating system you're using.
http://blogs.msdn.com/b/dcook/archive/2007/03/25/who-ate-my-memory.aspx
Jan 14, 2011 | HP xw9300 Workstation PC Desktop
P9i20 NEC 4 gb memory only 3 gb usable?
this is a known fault with Microsoft operating systems
Jan 22, 2010 | Computers & Internet
I add more memory to my microsoft vista but i don't see a difference in the memory
make sure that the "added memory" is detected and registered. if you got 4G before and you added a 2G module, 6G should be reflected at My Computer -> HArdware Properties
However, memory differences are only visible in running critical applications not in ordinary opening ang using of files.
Aug 26, 2009 | Microsoft Windows Vista Home Basic Edition...
I have a 64-bit computer and install Vista 64-bit. When I open System Properties, it clearly shows it is a 64-bit Operating System. However, despite having 5GB RAM, only 3.5GB is usable. This is typical of...
although 64 bit vista supports upto 128gb of memory but you should check whether all of your memory modules(ram) are working properly or not to check this go to the system bios and check it there if all the memory modules are visble
sometimes the chipsets on our motherboards share the system memory due to which ram shoewn in the system properties is less than the actual that is connected
Jul 09, 2009 | Memorex 4.7GB 4X DVD+RW 25 Pack Spindle...
Toshiba Satellite L305-S5907 2.0GHz Pentium Dual-Core T3200 4GB 320GB DVDRW DL WebCam 15.4" Vista Ho... (PSAG0U01900L) PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
