Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Saeco Incanto Rondo right red light is blinking all the time.
It started when I was done with my cup of coffee.
I put the brew unit and drip tray, dregs drawer properly in place. I fill 8 oz hot water . Nothing happened. It is still blinking.
Posted on Aug 25, 2011
  • blankluda Aug 25, 2011
    I set the machine to grind finer. It does't work
    Sergeant:
  • Saeco Expert
  • 223 Answers
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Posted on Jun 08, 2011
Coffee Beans do not grind
Try using the vacuum to clean out the grounds, then remove the brew unit and make sure the chamber from the grinder is clear.
Aug 11, 2009 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Rondo with a grinder related problem
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Bruce
Gold Roast Coffee
www.goldroast.ca
Jun 14, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco Incanto Rondo - Lower LEFT Red Light Flashing
Its been a long time since I posted but I just had to answer this one. :)
The left one is a indicator that its time to change your waterfilter,
If you dont have a waterfilter or if you have just changed it, press and hold the steam button for about 5 seconds and then the red light should go way,
Dec 29, 2008 | Saeco Incanto Rondo Fully Automatic Coffee...
Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
/Mirran
Sep 02, 2008 | Saeco Incanto Classic Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto Flashing Red Bean Light
I found a machine in my dentist's office with this exact same problem. I'm not familiar with the model, so I downloaded a manual for the closest model I could find online (the Sirius), and it offered no help -- but in 8 languages!
I ended up just pulling the drip tray, pulling the box where the grounds end up, and re-inserting the assembly (all while the machine was on.) When I buttoned it up again, it worked.
Hope this helps (although I can see how it might not...)
Nov 10, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
623 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
