Question about Maxi-Cosi Priori XP Booster Car Seat - Black
The seat belt has got stuck and won't move - Maxi-Cosi Priori XP Booster Car Seat - Black
  • Maxi-Cosi Master
  • 1,629 Answers
Hi Lisa and Paul - If your carseat is under 2 years old please contact your retailer with proof of purchase for them to assist you under the terms and conditions of the warranty. If the carseat is over 2 years old or you do not have proof of purchase please contact our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Posted on Nov 29, 2011
Honda seatbelt not coming out smoothly
There is most likely dirt debris and junk of all sorts from the life of the vehicle that is gathered up in the clean the gears and locking mechanism of a seat belt a good pair of cleaning behind the cover should solve your problem
Jul 12, 2015 | 1997 Honda Accord
My driver seat won,t move how do i fix it
I'm not familiar will your vehicle but check the basics , fuses ,see if there is anything under the seat stuck in the seat track. Find a wiring diagram an see if there are any relays an seat control modules involved ! You owners manual should tell you fuse position !
Jan 25, 2015 | Seat Cars & Trucks
Power seat
Most Fordicon1.png products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works besticon1.png to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Oct 21, 2013 | 1998 Ford Expedition
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
Sep 09, 2013 | Computers & Internet
Electric seat won't go forward or back. Sounds like it's trying
Aug 22, 2013 | 2003 Ford Expedition
My middle seat belt is stuck in my bmw x5
seat belt might be folded over in the spring loaded mechanism of the seat belt, which is preventing it from moving freely
Aug 10, 2012 | 2005 BMW X5
Why won't the driver's side seat belt in my 2012
possibly there is something stuck in the belt not letting it retract
Apr 15, 2012 | 2012 Scion xB Base Wagon 2.4L 4-cyl....
Seat belt pasenger seat
Are you trying to say the seat belt retractor is stuck? This is in the front seat?
If it's anything like my Tahoe, you need to remove the plastic panel that covers the retractor (carefully - don't break the clips or you won't be able to put it back on). Take a large flat head screwdriver and slide it under the part where the seat belt coils up, and find a little tab - push it with the screwdriver. As long as the seat belt is not twisted up, it should retract.
Nov 30, 2011 | GMC Cars & Trucks
The passenger side seat belt is stuck on my 1995 toyota pick uptruck.The belt can not be used and will not move (release) ineitherdirection. Any tips?
Replace it as it is no longer safe to use even if you did get it moving again. The ratcheting/locking mechanism has gone bad.
Mar 18, 2009 | 1995 Toyota Pickup
Forward and back movement is only 2 inches
sounds like youve got a kiddy toy stuck in the rail ,4 bolts and the seats out !! BE CARFUL of the spring loaded slider ( if it is spring loaded ) it will *** you if given the chance.
Jan 17, 2009 | 1998 Ford Explorer
Maxi-Cosi Priori XP Booster Car Seat - Black Logo
79 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
