Question about Bosch Ovens
Bosch HNT 1702 How to connect heating elements in oven.I need wiring diagram
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
bigg t
  • 640 Answers
SOURCE: blodgett oven
if you only have 3 wires to the element it doesnt matter how there hooked up.
Posted on Aug 11, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1462 Answers
    SOURCE: delonghi esf461st oven not heating up
    grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
    Posted on Sep 06, 2008
    • 20 Answers
    SOURCE: Element in top oven not heating up all the way.
    Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
    Posted on May 29, 2009
    Tip
    Common heating faults with Bosch HBL 5052 double oven
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
    4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 19, 2010 | Bosch HBL 5052 Electric Double Oven
    Is it possible to turn my Bosch oven in to 110 volt? Model number HBN58T650A Thanks
    I did a search for this Bosch oven-
    It sounds like the oven is not a conventional Resistance heating oven-
    So it might be possible--
    Do you have the manual for it?
    I tried this web site: visit the website: www.bsh-group.com.
    But It was not much help
    Perhaps you can look in the phone book, and contact your local BOSCH appliance dealer, and have them look up the model in their Model catalogs?
    Or-- You could pull the oven out, and check the wiring harness--
    No doubt it will tell where the main cord comes in, -- if there is a hook up diagram for both 110 Volt,and 220 VAC connection diagrams-
    When you get it out, tell us what you find-- maybe we can help further..
    MackB
    Jan 29, 2011 | Ovens
    Bosch Convection oven Coil
    I assume that you mean the circo therm element? If you do. Have you made sure that the wires that were connected are back on the same connections?
    I believe, I'm doing this from memory, you should have two red/white wires they attach to one side of the element and the other wire to the other side connection.
    Hope this helps
    deep Diver
    Jan 01, 2008 | Bosch HBL 745 Stainless Steel Electric...
    Tip
    Common heating faults with Bosch HBL 5056 double oven
    on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
    Tip
    Common heating faults with Bosch HBL3420UC Electric single oven
    on Jan 19, 2010 | Bosch HBL3420UC Electric Single Oven
    Tip
    Common heating faults with Bosch HBL 5032 single oven
    on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
    Tip
    Common heating faults with Bosch HBN 560570B / 560550B single oven
    on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
    Tip
    Common heating faults with Bosch HBN 430560B / 430520B single oven
    on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
    Tip
    Common heating faults with Bosch HBN 442 / HBN446 single oven
    on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
    Tip
    Common heating faults with Bosch HBL 742 / HBL 746 single oven
    on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
    Ovens Logo
    63 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
