Question about Whirlpool Ovens
How do you replace the lower heating element?akp120/ix
4 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
  • 2468 Answers
SOURCE: my oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Posted on Feb 22, 2010
  • 472 Answers
SOURCE: Have a frigidaire oven, model#
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Posted on Jan 12, 2011
Testimonial: "Thanks. I have no power going to the coil so I'll check the thermal cutoff."
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Nov 30, 2016 | Whirlpool Ovens
My whirlpool oven (AXP206/IX) is not reaching the temperature I want, 200c. It will only go to about 175c. Any ideas please?
are all the elements heating (glowing ) when on , ifnot then the ones that are not possibly need replaced .
Oct 28, 2015 | Whirlpool Ovens
Ignis AXL 905/IX oven and prob is food is cooking on top but not below. Two elements at top. Inner on when in oven mode, outer on in grill . Bottom of oven not warming evenly and burning top of food
Your bottom element is not working and that is why foods placed on top heat up but the undersides are not affected as much.
You need even heat on both sides of the food. Get a new element and replace.
Sep 06, 2015 | Ovens
Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
NEmmake sure you removed the correct item first
replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
Jan 26, 2011 | Whirlpool AKZ159IX Oven
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
I have a Whirlpool AKZ161/ix/03 double oven in which the bottom oven will no longer heat up to the required temp. I suggest it is the heating element. As a novice will I be able to change the element and...
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
Jan 27, 2010 | Ovens
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
May 17, 2009 | Whirlpool AKZ159IX Oven
No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Apr 12, 2009 | Ovens
Ovens Logo
22 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
