Question about Apple 6612926 COMPATIBLE LAPTOP LCD SCREEN 152 WSXGA MATTE CCFL (654367715000)
I have a g4 apple lap top with a 15'2 ? screen thats broke . where can i get a new lcd for cheap? #152 shelladorice@yahoo.com
  • Apple Master
  • 32,281 Answers
My apple power book g4 was dropped down and now it has a yellow tint.. i dont have much money to replace the screen as everyone says to replace.. any help to fix it?
If you are a bit handy you can order spare lcd`s and finde instructions on how to repair it your self here: http://www.ifixit.com/Guide/Repair/Installing-PowerBook-G4-Titanium-Mercury-Display/69/1
Do note, that you should have some experience in repairin laptops/electronic as this is not a easy opperation to do by you self, but its not imposible :) Best of luck!
Mar 08, 2011 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I have a powerbook g4 and have the screen show vertical lines...I heard about this problem and just wanted to know is it the the video cables or the screen it self
It's the screen itself, video cables produce a different problem. Easiest way to fix your problem is to match up the part numbers on the back of the lcd with a new or used one from ebay.
Make sure you match ALL of the numbers it's usually something like LTN152W5-L02
The dash and the numbers after it matter!
Most of them go for only 30-50 so it's an cheap fix, check out ifixit.com for full tutorial on how to swap it out ;)
Hope this info helps.
Oct 14, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Hello, My ibook g4 won't start up I turned it on and the chime goes as normal but the screen appears with the apple logos normal and the swirly loading sign but stays like that for hours and doesn't go to...
probably the software is courrepted.boot the system with installation disk and then check the disk with diskutility.repair the disk permission and check.if still the issue persist.reformate the drive and install freshly
Feb 09, 2010 | Apple Titanium G4 and 8413i Book series AC...
Broken apple g4 laptop lcd
Go on e-bay and buy you a new screen or a good used screen for cheap and do the replacement yourself. The process is really quite painless. Go to ifixit for the instructions or you can go on you tube and watch the videos.
Jan 24, 2010 | Apple iBook G4 Mac Notebook
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
PowerBook G4 15" Alumium LCD Cracked, see lines, HELP!!!
the new LCD is not match to your notebook. i'm sure not same all pin outs and pin in. its not compatible to the circuit board of notebook. even the LCD connector is also not compatible.
May 30, 2009 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
My laptop ibook G4 power button is not functioning even if press
have you got it plugged in too charger, power button wont function if no charge in battery..... easy to forget when your freaking out about your 3k lap top... goodluck Chas
Jan 31, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Oevrall screen is black
First off where did you buy the replacement screen? Second did that screen also come with new ribbon cables?
If you bought the replacement online and just installed it without reading the instructions or it didn't come with any then you have the reason there.
If you did read the instructions and followed the steps correctly, then did the replacement come with new ribbon cables and connect lines is the next part, because the reason the first screen failed was not only the screens dynamics, but the constant open and closing, bending causes the cables to get worn in the same area and eventually it will tear or just break. And since you stated that the hinges had broke first that automatically says that the screen will fail due to not being able to function as it should. So with that said, and your answer was YES to the new cables, then final step is to retrace your steps when installing. Because you forgot to reconnect something to have the screen light up. If the white light on the screen doesn't light up you will see what you see now.
I suggest you to goto ifixit.com they have a step by step with images to install or replace parts on all Apple portables. Just follow their instructions correctly to find your PowerBook and then use their install steps.
-Luke
Jan 19, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Powerbook G4 1.67 GHz LCD problem
Probably more like a Video cabling issue or a Screen assy getting bad connections.. Both have been seen here.
Jul 16, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 6612926 COMPATIBLE LAPTOP LCD SCREEN 152 WSXGA MATTE CCFL (654367715000) Logo
88 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
