Question about Viking Grilling
Viking outdoor grill, VGBQ410-3NSS
My control knobs and ingition machanisims were burned because of the oil from the BBQs. I like to repair them but I don't know which parts to order and replace. My burner units wad been replaced about 2 years ago and still in good condition.
SOURCE: Replacement parts for George Foreman Grill GGR50B
Try Fox International at 1-800-233-9054 or on the net
at fox-international.com They had the power cord (Heat Probe) for our GG50 (no "B")
Posted on Apr 08, 2008
burzerko
  • 254 Answers
SOURCE: gasgrill
No you need to replace the valve behind the knob as well most likely this is what caused the flame.
Posted on May 31, 2008
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
  • 582 Answers
SOURCE: Outdoor grill with no gas pressure, little heat
TURN THE TANK OFF , THEN REMOVE BURNER ASSEMBLY AND CHECK FOR OBSTRUCTION IN THE GAS LINE AREA . IT IS NOT UNCOMMON FOR SPIDERS TO BUILD WEBS INSIDE THE TUBES AND CAUSE MAJOR PROBLEMS
Posted on Aug 22, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
How do you light the gas grill
I assume outdoor gas grill? If so, turn on gas at tank. There should be a knob that has a lightening bolt or something similar representing ignition. Turn the knob to that diagram and click the igniter till it lights. If you don't have igniter use a long grill lighter. Once that is lit you can turn other knobs that control other rows of gas if so equiped.
May 17, 2014 | Magic Chef Ovens
Replacing ignitor
That is not really enough to tell us what you need.
We repair a lot of Viking model barbecue grills and stock all the various ignition parts. As Viking changed fabrication strategy the appliances have gotten much better through the years. An electrode purchased today for a Viking will not look the same as the original electrode but the new, longer, double-pronged electrodes work a lot better, are built a lot heavier, last a lot longer and cost less than the originals.
The only difference between the module and electrode and button architecture in a Viking when compared to any other high-end grill is the inner firewall. Between the control panel and the inside firewall inside the grill where the burners connect to the valves, there is a second firewall designed to hold-off heat damage created by certain problems (usually resulting from poor assembly after cleaning). The new Viking electrodes are long and thick but the back-end is also long which makes sure the electrode wires are far away from the heat of the firebox.
Other than that the 9volt module, button and electrodes are no different from any other high-end grill.
We do have exploded schematics of where all the grill parts belong in a Viking so contact us if you want copies of this information.
Jan 25, 2014 | Viking VGBQ410-3RT Grill
The left burner of my Thermador CGBD30RX Grill lights only sporadically, I would say about 30
Have you taken off the control knob and see if you tighten the body of the tap .
May 21, 2012 | Thermador CGBD30RX Grill
Rotisserie burner has to be lit with a match and will not stay on by itself. I have to push control knob in, even after it is hot. Also looking to replace igniter for left burner. Thanks.
From what you are describing, it sounds like your rotisserie burner may have a bad thermocouple. You can order the parts from Viking, the igniter for the left main burner will require you to remove the front panel to replace, but is fairly straight forward after that. To replace the thermocouple, you will have to fish it down from the burner and under the grill to behind the front panel, not hard, just time consuming.
Jun 19, 2011 | Viking VGBQ410-3RT Grill
I lost door handle,can i buy new one from you?
No, no products are sold here... only adivce on how to repair..
You may want to doa search for "Lynx outdooe grill knob" to see if there are parts available..
heatman101
Apr 27, 2011 | LYNX OUTDOOR GRILL DOORS LDR21 1
I cant find my serial number on my outdoor viking profesional barbeque i need it to see whats guranteed , and order parts
Manufacture's put this information in a variety of places, check the back of the cart/grill, check inside the door, check the underside of the grease pan, and then, pull out the grease pan and get down on your knees and check up above where the grease pan slides in. Hopefully, it will be in one of these places.
Jul 13, 2010 | Viking VGBQ410-3RT Grill
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
Grilling Logo
70 people viewed this question
Top Viking Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Mike Hollander
Mike Hollander
Level 1 Expert
Are you a Viking Grilling Expert? Answer questions, earn points and help others
