Question about Microsoft Windows XP Home (vis-winxph) for PC
We were told we needed to format and reinstall windows since there were a lot of folders in windows folder that were marked as uninstall in blue writing now that we did this I notice our windows folder still has all these unusual folders
  • 76 Answers
Those folder are not unusual, they are folders that have file compression enabled, so you dont have to uninstall any of them.
You can disable file compression by;
Right-click the file or folder and click properties. Click advanced. There is a check box for Compress contents to save disk space
hope this helps
Posted on Apr 09, 2011
  • cpenzes680 Apr 10, 2011
    So do I want the box unchecked and should the other boxes be checked or unchecked
    And is it okay to delete the folders that say uninstall with $and #'s
  • djwordz Apr 10, 2011
    Yes, uncheck all the boxes, you dont need to uninstall any of them
Sony 8gb pendrive not detected
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Jan 29, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Tip
3 Important Tips for iTunes on Windows for the non-MAC users There are times...
There are times that software would bug down or get messed up. We do not have total control over them. Either software gets infected or damaged by a virus or even for an unknown reason its files just get messed up. Same is true for iTunes.
There are times that we experience doing an upgrade for iTunes and then all of the sudden it stops, crashes or this nasty little error window would pop-up. There are even times that we had to reinstall iTunes and, upon doing so, discover that we have lost our valuable music. This guide is the answer to all that problems.
Tip#1: Make sure that you know where all your data is being saved. For the iTunes Media Folder, the location is in your My Documents Folder ("My Documents\My Music\iTunes" to be exact). And that is the default location unless you changed it manually. Now, why do we need to know this. Simple. If things get messed up, this is where all your precious music are located. This is the folder you need to backup.
Tip#2: How do you make sure that all your music, downloaded or imported, is in that iTunes folder? What you need is to setup your iTunes to copy everything there. The reason why you need to do this is that everything will be organized. You would not have your music files all over the place or in different and random location, which would just give you headaches later on. You would then not need to search all your folders for your music files. Also, this prevents you from having problems during iTunes reinstallation where in most cases a lot of people would suddenly discover that some or a lot of their music is missing right after that process. So, how do you do this? On your iTunes menu at the top, click Edit. Then click Preferences. Click the advanced tab. Here you will notice that you have the location of your iTunes Media Folder. Right below that make sure you have a check on "Keep iTunes Media Folder Organized" and "Copy files to iTunes Media Folder when adding to library." The last item is the important one. This makes sure that all your data is copied to that folder. This item is by default not checked. So, make sure that there is a check mark on it.
Tip #3: What happens if the inevitable happens? If I could not update iTunes or if iTunes gets messed up? What do I do? As long as you have followed Tips #1 and 2, you are safe from the hassle of searching, downloading and importing all your data again. First, go into your iTunes Media Folder and copy all your data to a separate folder. This is your backup. Now, it is safe to uninstall iTunes. After you have uninstalled and reinstalled iTunes make sure that you follow Tip#2 again. Then after that just import them all back using iTunes' import functionality under the File Menu.
Now that you have these 3 steps you are all set and confident that, whatever happens to your iTunes, you will be able to recover all your data.
on May 04, 2010 | Apple iTunes
It says USB device not recognized
Hope it helps.
Jan 20, 2013 | Eclipse CLD2 MP3 Player
I uninstalled a program that had named itself program files, and I think it uninstalled everything on windows XP I don't get a login screen anymore
The only thing i know to be named "Program Files" is a default folder created upon installing the OS. It wouldnt be a program, its a folder where the programs you install are stored by default. if you did delete this folder, you may no longer have a working OS, and might need to reinstall your OS.
Jul 02, 2012 | Microsoft Windows XP Home Edition English...
How to get my flat bed scanner to save in pdf format? For years I have been able to scan documents and save as pdf or choose another format such as bmp or jpeg. I have of remove the software and reload...
There are 2 steps you can do to get this option back.
First, You need to update Adobe Flash player Or you need to uninstall and Reinstall the Adobe Flash player.
Since you uninstalled the Software and and reinstalled, the Software is not able to detect the latest Adobe software in your PC.
May i know what is the operating system ?
Try this step below to update to adobe flash player if you are using Windows XP or Windows Vista
Click on START button
Click on MY Computer or Computer
Open C:/ local Disk
Open Windows Folder
Open System32 Folder
Open Macromed Folder
Open Flash Folder
You will find few flash files
Double click on file Flashutil10 and it should give you update screen. Continue and complete the process.
Restart your PC and try to Scan
If this does not work, you need to uninstall adobe flash player and reinstall it and it will work.
Regards,
Ron
Mar 09, 2011 | Microtek ScanMaker V6USL Flatbed Scanner
Hi, my name is victor. I have a HP Pavillion dv9225nr entertainment laptop, with amd turion dualcore x64, 4GB's RAM, and a Pioneer slimline dvdrw drive. the drive is a (pioneer dvr-kd08hb____1k09_...
Hi digitaldr445 !
This is one solution , maybe not the easiest one nor the best one but it will work .I understand you have the Win 7 install disc :
Back up your data , especially the drivers .
Extract the hdd out of your lap , put it in a external USB box or use a specific connector to connect the drive to a healthy pc . Format the drive . Place it back into your laptop and reinstall
Windows 7 .
Best regards .
fanaudi .
Feb 25, 2011 | Computers & Internet
Was told to uninstall and then to reinstall will not let me unins
To view hidden files in Windows VISTA
1) Open Control Panel and open Folder options
2) Click on View and select the option " Show all hidden files "
3) Click Apply and click Ok.
Uninstall the software
1) Disconnect the printer from the computer or network.
2) Click on Windows button on the Computer.
3) Type %Temp% in the box and then press Enter to open it.
4) Locate and Click on 7zs2b7.tmp folder to open it, if not found, check for any folder starting with 7z.
5) Open that folder and then locate Util folder and open it.
6) Double Click on CCC folder to open it.
7) Double click Uninstall_L3
NOTE: For 64 bit, the uninstallation file will look like Uninstall_L3_64 and for 32 bit it will be Uninstall_L3
priscilla : Once the uninstallation is complete, restart the computer and install the All-In-One software.
priscilla : In case if you have any questions or clarifications please use this Activity ID:1742091 as reference when you login again to the "HP Total Chat Support" this will help us to serve you faster and better.
priscilla : Thank you for contacting HP Total care and giving us an opportunity to serve you. It's been a pleasure assisting you today.
priscilla : Bye and take care.
Feb 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
My authorization #is 8011089608. I was told if I kept having problems to run my recovery disk. I cannot get my disk to run. Please walk me through that. I may be doing it wrong. My computer is totally...
Hi Irene,
Firstly defrag your C drive. Be patient as it'll take time. After having done that, go to Start > Settings > Control panel > Add/Remove programs. In that see whether you have uninstalled all components of Norton Antivirus (Live Update, Etc.) If so, then close that window and again click on Start go to Run... & in the dialogue box type regedit and hir ENTER.
Make sure you're disconnected from the internet. Disable your ADSL/Dialup line before you begin this procedure.
(Now be very very careful here. You'll need a lot of concentration. So be patient & keep a track on your clicks & keystrokes)
Press F3 (for Finding a key value) Here type in Symantec and hit ENTER. It will search and display on the right hand window, anything & every thing to do with Symantec. But here you will ALSO have to see what folder is opene on the left hand window. IF the folder opened is pertaining only to the key value shown on the right then just delete the entire folder in the left window ELSE delete only the line that has "Symantec" mentiond in its key value string on the right side window. Now hit F3 again and follow the above step till everything related to Symantec is removed completely from the registry. You will konw this when a message window will appear stating, "Finished searching Registry".
Now collapse the entire Left side folder hierarchy to its basic form and hit F3 again and in the dialogue box type Norton & hit ENTER. Now do exactly what you did to remove Symantec entries form the registry. After having done that, restart your machine and see if your problem has been solved.
If you are still stuck, then you need to repair your Operating System. (Repair... NOT format & reinstall)
May 05, 2008 | Computers & Internet
Will not run
the better choice you have is uninstalling it and reinstalling it again.
you may have a corrpted program file, or corrupted program info in registry.
both impossible to track manually, then i advise you to full reinstall it.
Nov 30, 2007 | Webroot Spy Sweeper (spysweeper) for PC
Photo explosion won't start. one day it was working fine the next not at all, I tried unitstalling and reinstaling to no avail
I had the same issue and uninstalled it, cleaned up the registry, re-installed it numerous times and still nothing. Then I changed the compatibility for the .exe to Windows 98/Windows Me even though I am running XP and it started up.
Oct 31, 2007 | OnDemand Photo Explosion Deluxe 2.0 for PC
Microsoft Windows XP Home (vis-winxph) for PC Logo
123 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
