Question about Simplicity Toys
Is my simplicity crib on recall model number 8995MLH Manufacturer code 3607-hs
SOURCE: lost crib instructions please help
It seems that the company may be out of business. I have been searching for instructions for an 8748AWT for a long time and have never found them.
Posted on Mar 13, 2009
VulcanBrat
  • 23 Answers
SOURCE: need instructions for Simplicity 8995MLH
From the company website:
http://www.simplicityforchildren.com/letusserveyou/productmanuals.htm
Our instruction sheets are available upon request.
Please call the Customer Service Toll-free Hotline:
Mon thru Friday - 9:00 am to 5:00 pm EST
1-800-858-8323
Or e-mail Customer Service:
customerservice@simplicityforchildren.com
Posted on Feb 03, 2010
Dajuliehubby
  • 203 Answers
SOURCE: i have a simplicity crib model number 8676 and was
Yes, this model has also been recalled. Here are some web pages with information on the recall.
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10211.html
http://www.newsinferno.com/archives/20005
Hope this Helps :) Don't forget to RATE!! :)
Posted on Aug 13, 2010
  • 16 Answers
SOURCE: i need a manual for
simplicity is no longer in business and it is on recall. bring it back to the store you bought it from and get refund or exchange it for a different company
Posted on Oct 03, 2010
ZJLimited
  • 17970 Answers
SOURCE: How do I convert my
Check this procedure...
1 Remove the front panel of the Simplicity crib. Use the Allen wrench provided with the crib (you should have stored the wrench and extra bolts in the pouch under the crib when you first assembled the crib). There are two 45mm bolts on each side of the front panel.
2 Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3 Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4 Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5 Store the front panel of the crib carefully. Wrap it in blankets to prevent scratching. The front piece can be used later to turn the toddler bed into a full-sized bed.
Also, could check some recals in THIS LINK.
Hope helps.
Posted on Oct 18, 2010
I have a simplicity for children crib model 8992 and I lost the instructions can anyone tell me where to find them thanks
Simplicity is out of business and their cribs have been recalled.
This recall will be carried out by retailers since the manufacturer is no longer in business. These cribs were sold at Walmart, Target and Babies R Us stores. You should contact the store where you purchased the crib to receive a refund, store credit or replacement crib.
Do not attempt to fix a recalled Simplicity crib. Please find a safe, alternative sleeping location for your baby until the crib can be replaced. It's important to note, as well, that all Simplicity drop-side cribs are already under recall due to a problem with the drop-side.
http://www.cpsc.gov/en/recalls/2010/simplicity-cribs-recalled-by-retailers-mattress-support-collapse-can-cause-suffocation-and-strangulation/
Oct 30, 2013 | Baby Gear
I purchased a Aspin 4-in-1 crib from walmart in 2007 (Model number 8756ACG/ Manufactures code 4507DH). I am looking to set it up for our new baby and have noticed that I am missing the plastic track that...
Your crib was recalled and company is out of business. DO NOT USE FOR YOUR NEW BABY.
This recall will be carried out by retailers since the manufacturer is no longer in business. These cribs were sold at Walmart, Target and Babies R Us stores. You should contact the store where you purchased the crib to receive a refund, store credit or replacement crib.Do not attempt to fix a recalled Simplicity crib. Please find a safe, alternative sleeping location for your baby until the crib can be replaced. It's important to note, as well, that all Simplicity drop-side cribs are already under recall due to a problem with the drop-side.https://www.cpsc.gov/en/recalls/2010/simplicity-cribs-recalled-by-retailers-mattress-support-collapse-can-cause-suffocation-and-strangulation/
Oct 01, 2013 | Simplicity for Children Aspen 4-in-1...
Need instructions for Simplicity 8995MLH
1-800-858-8323
Feb 03, 2010 | Simplicity for Children 4-in-1 Convertible...
We recieved a simplicity for children crib,dresser, and changing table with no instructions.Model#8050N manufacturers code 0108hy please help
About 1 Million Simplicity Cribs Recalled Due To Failures Resulting in Infant Deaths
The firm appears to no longer conduct day-to-day operations. Repair kits are no longer available to fix these recalled cribs. Parents and caregivers are advised to dispose of these cribs, even if it is believed that the hardware and drop side have been installed correctly. All of the recalled cribs have the potential to pose a danger to young children.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
Oct 10, 2009 | Simplicity Baby Gear
I have a simplicity winnie the pooh, 3 in 1 bassinet.. i would like to know if this product has been recalled because i saw at walmart that similar ones have been.
READ IMMEDIATELY!!!
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09319.html
You can often find model numbers for recalled cribs on manufacturer labels on the crib's underside, headboard, or footboard or on mattress support boards. If you're unsure, call the manufacturer.
Oct 04, 2009 | Simplicity for Children 4-in-1 Convertible...
I NEED TO KNOW HOW TO TURN CRIB INTO DAYBED
I suggest you checking the simplicity web site for instructions. You may also want to check your cribs model name/number to the list of recalled cribs made by Simplicity. The following link is the company website for Simplicity, http://www.simplicityforchildren.com/, the next link is the direct link to the recall list: http://www.simplicityforchildren.com/ourproducts/notice_dropside/index.htm. There are also numbers you can call which should be listed on their webpage. Good luck!
Jul 30, 2009 | Simplicity for Children Aspen 3 in 1...
Need instructions simplicity crib model #8995MLH
Hi I do have the instructions for this model , let me know if you still need them, also I need to convert the day bed into a crib againg , so if you have the bottom rails ( wich Iam missing) we can exchange this items, I hope it works for you . let me know
Apr 22, 2009 | Simplicity Baby Gear
I need an assembly manual for a Simplicity 8943hcd ''Havana'' crib. Gift did not come with instructions.
I have a crib model number 8943HCD we are trying to change it from a crib to a full size bed we lost the instructions could you please help us my e-mail is apryllewis@comcast.net the manufacturers code is 2008-HS
Apr 11, 2009 | Simplicity Baby Gear
Lost crib instructions please help
Mar 13, 2009 | Simplicity for Children 8994W Crib
Toys Logo
123 people viewed this question
Top Simplicity Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Simplicity Toy Expert? Answer questions, earn points and help others
