Question about HP ScanJet 2400 Flatbed Scanner
When I start scanner it starts with it is warming and no furtjher scanning
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Im assuming that it has worked before. My suggestion is that if its under a year old you contact the manufacturer here at www.hp.com If its older than a year and out of warranty you probably need the scanning lens replaced and to be honest with you if that is the case and you have to pay for repairs buying a new one will be much cheaper for you.
I hope this helps you out if it does please give me a YES that I did try and assist you. Thank you
Posted on Apr 09, 2011
I have a MG5550 all in one I try to scan a paper and get a error code 3,202,19
The error code you have given does not follow the normal Canon way so I cant find it. However, does the scanner lamp actually lite? I suspect it does not so it never warms up. If the scanner is locked it would tell you first before it even gets to the warm up. If the lamp does not lite then a new one would be needed. They are not easy to fit by any means and really a Canon trained engineer needs to do it. sorry but that's the best info I can give you.
Feb 28, 2016 | Canon PIXMA Office Equipment & Supplies
How to scan passport photo
How to scan a document or picture using Windows PAINT
Turn your printer/scanner on!
Click START
type PAINT
click PAINT under programs at top
untitled-paint window opens
in top left corner click the little white arrow
click FROM SCANNER OR CAMERA
choose settings you require
click preview (scanner may have to warm up for 20 seconds)
preview appears in window
adjust edges if need be (click/hold/drag)
click SCAN
item appears in Paint
ckick the white arrow again and choose SAVE AS, give it a name and click SAVE (it will automatically save it to PICTURES)
you can now RESIZE or ROTATE the scan
you can also add text to it by clicking the letter A and drawing a box on the scan
If you want to email it, just close Paint, go to PICTURES, right-click on the scan and choose SEND TO then MAIL RECIPIENT
Aug 26, 2011 | HP Officejet 4355 All-In-One InkJet...
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
Apr 26, 2010 | Epson 2580 Perfection Photo Scanner
The scanner warms up and goes through its process but does not transfer picture to screen - comes through a blank white page and then the screen turns black reinstalled the driver and rebooted the computer...
Most of the scanner software has options to set the scan area. Yours MAY have got set to a tiny area outside the thing you are scanning. So check the options including the scanning resolution. Reinstalling the I/O driver is useless. Re-installing the scanning software itself MIGHT restore the resolution to defaults. If there is a way to restore defaults, try that.
SOMETIMES re-installing software remembers your old settings, which could be the problem to start with.
Mar 26, 2010 | HP ScanJet 2100C Flatbed Scanner
How do i use my scanner
If you have loaded the software for the printer/scanner.
Go to your HP director Icon and start this program.
you should see your Scanner / printer listed under Select device.
You can place a document/picture in the document feeder on top.
OR you can place the document / picture directly on the glass.
(Lift the hinged lid to reveal the scanner glass)
Don't worry the document feeder uses a different scan wand.
Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
You are not limited to just the HP director.
Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
97 toyota camry stalls after warm and at stops or hard starting also strong gas smell on starting.
you will need to get the vehicle diagnosed thru dtc scanner. scanning the dtc's will tell the tech where to start and most likley exactly what the problem is. sounds like a possible cam or crank sensor.
Sep 24, 2009 | 1997 Toyota Camry
My benq 5000 scanner still warming up
how to down load the soft ware of this model
Aug 31, 2009 | BenQ Scan to Web 5000E Flatbed Scanner
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
HP ScanJet 2400 Flatbed Scanner Logo
169 people viewed this question
Seeker5211
Seeker5211
